RPM's....where for a 6.0 - Ford Powerstroke Diesel Forum
Old 09-16-2009, 03:18 PM
Ok guys, where is the best RPM range for a 6.0 to run at while cruising on the freeway. no matter the speed....is it 1900, 2000, 2100, 2200, 2300 ect......
Old 09-16-2009, 03:26 PM
What do you mean by best? Best fuel economy or best power range for cruising. I would say 1900 RPM would be the best for better MPG and it can still pull itself easy unloaded.
Old 09-16-2009, 03:28 PM
Unapologetically American
Feedback Score: 4 reviews
I run from 1900 to 2100, depending on the hill/road
Old 09-16-2009, 03:47 PM
Mine with 3.73 gears run approx 2000rpm at 70-75mph.
your motor will be alot different than mine though.
Old 09-18-2009, 10:20 AM
Only the truck 1,900- 1,800 is good.
Old 09-18-2009, 10:24 AM
Feedback Score: 5 reviews
anything under 2k will yield the best fuel economy while unloaded
Old 09-18-2009, 01:17 PM
X2^^^
Old 09-18-2009, 01:59 PM
Lt. Negativity
Ok operating rpm's matters when you running a different turbo, anything below 1900 on a non-vgt is a pain trying to keep it spooled. On a VGT style its easier, If I remember correctly you were looking into a Non VGT. So a little higher RPM will benefit you and help keep the turbo spooled.
Old 09-18-2009, 03:01 PM
I keep mine humming around 32-3300!
Lol, not really...on the highway its typically around 1900
Old 10-09-2012, 07:42 AM
i have a similar question
I am looking at a 2008 f450 with the powerstroke. i will be using it to carry 4200 lbs full time as a truck camper...
the truck i am looking at has 4.88 rear gears and does 2600-2700 rpm at 70mph...
is this a good operating range for this engine, i have never owner a diesel...
or should i be seeking something with a taller gear, like a 4.10 or 3.73...
thanks in adavnce
david
