What psi are you guys hittin? Only mods I have are in the sig. I run Extreme Street all day everyday.
Wow the other night I hit 36 psi boost, sure hope my heads are still bolted down ![]() I can hit 30-33 ish all the time but 36 that was scarry cool. |
I know how you feel. Towing my fiver over the fourth I caught my gauge pegged at 35 a couple times. I can normally pull into the 30's when tuned.
i can grab 33-34 with my 7.3
Give it another fall down the board.
i get about 34 at WOT.. And just a lil bit more pulling 10k
first off i'm not disputing that the boost is there but i know that on my semi that i have to replace the boost gauge at 2 years or less because they get weak springs and they read higher than what is actually there.
The big cat seems to throw a lot of excessive boost codes after 55psi and I can't turn on the propane till I have at least 40 psi. |
i can hit about 33-34 at wot with mine
I have Erics extreme street and I can hit 35-36 psi in an 07.
I tend to stay in the mid 30's!
