Quad Pillar and Gauges.
I have a 2004 F250, would like to install a quad pillar and Gauges. From what I have read on here, the auto meter gauges are the way to go. What four gauges should do I need and where to get them and a quad pillar?
Thanks, Kelly |
i have 2 pyros (one in each manifold) boost, and trans temp. i got mine from DPP (diesel performance plus)
I have a fuel psi, boost, EGT, Coolant temp, trans temp, and a volt gauge.
boost, EGT, tranny temp, and whatever else youd like, id go with a volt meter.
lots of places sell them. Raul @ stealth automotive could probably set you up right! |
if you had to go 4 i would go with boost, pyro, trans temp and fuel pressure...
but you dont really need 4... the fuel pressure gauge by itself is over 200 bucks if you need specifics just let me know -Raul |
Hey Raul, I'll give you a call when I get ready to do this mod.
Kelly |
I like the a-pillar mount (4 guage) but are there any other mounts that look good installed? I could see have 6 or 7 total guages (water temp, volts, egt, boost, trans temp, fuel press, oil press)
