EGR Valve Delete
Would this egr valve delete kit prevent an EGR cooler failer? I don't see if the cooler failed how coolant would get back into the intake.
What issues do you see with doing this and not blocking off the cooler at the up pipe? Ford 6.0 Diesel EGR Eliminator - Spool W/clamps - bolts:eBay Motors (item 280354215158 end time Sep-02-09 07:32:49 PDT) |
no deleting the EGR valve will not prevent the EGR cooler from failing.
yep, had mine blocked and welded and the cooler still failed, hydrolocked the engine and cracked both heads
