Another SCT X3 help thread. Sorry - Ford Powerstroke Diesel Forum
Old 07-19-2009, 06:15 PM
When I plugged the X3 into my truck to program it, it came back with "Unlock ECM failed". I bought it brand new and I've looked around the forums for help but I can't find anything about it. Any suggestions?
Old 07-19-2009, 06:59 PM
Illiana Chapter Director
It does this when you first plug it in? Can you get to any of the sub menus?
Old 07-19-2009, 07:03 PM
No, I can get to all of the sub menu's. The problem occurs when I go to program vehicle. I select the tune that I want to run and when I click begin programming it stops for a little, then comes up with the error message. If it helps, it also says that it can't upload the stock file from my truck.
Old 07-19-2009, 07:06 PM
try returning to stock from the menu then try it? i dont know it might help
Old 07-19-2009, 07:14 PM
When it asks you, do you select "pre-loaded" or "custom"?
Old 07-19-2009, 07:16 PM
I select custom
Old 07-19-2009, 07:27 PM
I select custom
Ok. Have you already sent your PCM strategy code in and gotten the custom files burned and emailed to you?
Old 07-19-2009, 07:33 PM
Yeah I actually just did that a few hours ago. They downloaded onto the programmer and I can see them when I select custom tunes or whatever in the Program Vehicle submenu. Looking through other threads, I keep seeing people say download 3 things from the sct website, yet when I try to download the software, I only see 2 things to download, the device firmware and the device update software.
Old 07-19-2009, 07:39 PM
I haven't gotten that far with custom tunes yet. Will it let you load the pre-loaded tunes?
Old 07-19-2009, 07:44 PM
I'll go try it now, but I was under the impression that teh new X3's had no canned tunes?
