EGT and boost guage question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-17-2009, 04:58 PM Thread Starter
mustangman02232's Avatar
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
all right so ive had my guages installed for a few weeks now and have a few questions, first, i mounted my pryro a few inches after the turbo (on the DP) but it seems that the manifold is prefered? whats the temp differance between it mounted on the manifold and DP (how hot can i get with it on the DP?)
also, my boost guage flutters around alot and i dont think its reading acurate, could this be a guage/connection or is it something with the truck itself?
2009 F350 CCSB Lariat 5.4
fisher MM2, 20% tint, leveled
2003 mustang cobra vert
SLP LM1, CAI, diablow tuner
2004 F350 reg cab 4x4 6.0 (SOLD)
exhaust/tune/deleted, dieselsite coolant filter, CAT ELC, blue spring, fisher MM2,
13.9 @95 mph
2002 Mustang 3.8 auto vert boltons (SOLD)
90 F350 RCLB IDI (SOLD)
mustangman02232 is offline
post #2 of 9 Old 07-17-2009, 05:01 PM
jasonsthilaire's Avatar
i think the temp diff is like 200-300 less if i remember right but dont take my word for it, and did you just install a tuner or such? because the fluttering is probably turbo surge but you should be able to hear it also.
jasonsthilaire is offline
post #3 of 9 Old 07-17-2009, 05:02 PM
For the boost gauge do you have it hooked up to the map line? If so that would explain the fluttering gauge. You should tap the boost elbow and put it in there. That will give a more accurate reading.
03-blue-Powerstroke is offline
post #4 of 9 Old 07-17-2009, 05:08 PM Thread Starter
yea it is, i can try tapping the elbow this weekend, and would i be safe to say keep the EGTs below 1000* with it on the DP?
13.9 @95 mph
post #5 of 9 Old 07-18-2009, 04:36 AM
Im not to sure about that. I have heard that with the sending unit after the turbo that the temperatures can be off anywhere from 2-400 degrees. Obviously they will read alot cooler.
post #6 of 9 Old 07-18-2009, 07:19 AM Thread Starter
1300* is max safe in the manifold right?
13.9 @95 mph
post #7 of 9 Old 07-18-2009, 08:13 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
you need to put that pyro pre turbo at the elbow of one of the manifolds, post turbo isnt as important as pre turbo.
The boost flutter is from it being tapped into the map sensor, drill and tap the intake elbow and this should eliminate the boost gauge flutter.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #8 of 9 Old 07-18-2009, 10:54 AM
yea I had mine in the DP as well, BTS moved it to the manifold for me when I got the EGR delete. Far more accurate and a much quicker reading. I would keep it under 1000 until you move it!
Ruben
2008 F250 4x4 6.4PSD Auto
Tuned, deleted, studded, piped, bts'd...
Rubenk is offline
post #9 of 9 Old 07-18-2009, 03:38 PM
smokersteve's Avatar
Quoted: 20 Post(s)
Put it on the manifold but id be great to put 1 on each.
If you putting it on the dp add 200* just to be safe
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
