What should i do next?? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 07-17-2009, 10:59 AM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
So i had been thinking, i dont really need anything cosmetically for my truck, so i want to start saving for something good, performance wise.. i am tuned and have a 4" exhaust, what should i do next?? i dont run it hard, so i havent seen the need for studs yet, although they will be done eventually.. what can i combine with my tuning to get a little more out of my engine but still be able to keep it as reliable as it has been????? seems the tuning itself is getting kinda boring now..
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #2 of 22 Old 07-17-2009, 12:55 PM
What do you have now?
06 F350 Traded
alwil is offline
post #3 of 22 Old 07-17-2009, 12:56 PM
We need a picture to look at to see what you have done.
03-blue-Powerstroke is offline
post #4 of 22 Old 07-17-2009, 01:40 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
All stock except my exhaust and sct tuner. I'm not looking for anything cosmetic, I want performance. Engine wise, tranny wise.
at any time.
Rob is offline
post #5 of 22 Old 07-17-2009, 05:12 PM
scubaman1991's Avatar
u can get bigger tunes for your sct.idk much about it but maybe water/meth
2006 F-250 6.0
k&n FIPK cold air
SCT X3 tuned by innovative
cat-back straight pipe
37" bfg all terrains on factory 17'
s
scubaman1991 is offline
post #6 of 22 Old 07-17-2009, 05:32 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Rob are you still running the stock 3.73 gears or are you regeared for your 37's?
If you arent and you want some added performance that would be my suggestion
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 22 Old 07-17-2009, 06:41 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
That may be a good thing to do since I am still running the 3.73's
at any time.
Rob is offline
post #8 of 22 Old 07-17-2009, 06:44 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
That would be the best idea yet. Get ya some 4.30's That would put you back to the stock gear ratio and give you full use of your tunes. It will run roughly 1500 bucks installed both front and rear but it will be worth it.
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 22 Old 07-17-2009, 06:57 PM Thread Starter
Rob
Rob's Avatar
Quoted: 2 Post(s)
4.30's huh. I have heard people going to 4.55's or something. What can I expect with new gears??? Hopefully better takeoffs
at any time.
Rob is offline
post #10 of 22 Old 07-17-2009, 07:07 PM
winchester33's Avatar
i'd say an egr delete and studs... just to keep it reliable for future mods. i guess injectors, turbo and a tranny afterwards. Gears wouldn't be a bad mod but it wouldnt make a huge difference. if you want something just to play around with... get studs and nitrous. but eventually that would become to expensive. it all depends on what you have to spend. the more $$$ you have, the faster your truck is.
2008 Ford F-250 6.4L
winchester33 is offline
