How to get into the 13's?
What do i need to do to get my truck in the 13's safely? Granted im in WA at a lower elevation so it should be a little easier.
SCT with custom tunes, exhaust, and gauges will get you in the high 13s
Add head studs to that list if you don't already have them. Thye won't make you any faster, but they'll keep your head gaskets intact.
Put your truck on a trailer behind mine. That ell get you in the 13's just kidding
SCT, Exhaust, and Nos! Evan ran in the low 13's with this set up on a Extended cab Long box.
-French |
I got a SCT with tunes from Cale... lost the Tail gate and the truck box. and ran 13.8... truck weight was 7100# even at time of run I also have Banks highram, 4inch from down pipe back, cat delete and a K&N FIPK
With an SCT with CUSTOM TUNES, you should see high 13s, low 14s, depending on cab configuration, longbed/shortbed.
I'm pretty sure Evan went low 12s running his SCT and No2 |
when do i have to start worring about improving tranny parts?
From your picture, pull forward about 10 feet then step on it, that'll get you in the 13's with the look of that downhill slope
You running an automatic tranny?
YA 13 SECONDS TO DEATH! lol ya its an automatic
