Studs without cab removal ? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-08-2009, 03:02 PM Thread Starter
Weathermanmc's Avatar
Is it possible to do head studs without removing the cab? I have an 04 and would sure like to get studs done but really dont want to have to lift the cab...Looks like a real pain in the a$$ !!!!!!!!
Michael
2004 F-250 lariat 4x4
SCT, Innovative tunes!
AFE intake, Banks 4" turbo back
Fass fuel system,
RCD EGR delete
ELC coolant
High idle, Fog, Zoodad mod
Modified Fuel Banjo Bolts,
Boost, EGT, Trans Temp, gauges
2" front leveling kit
3" blocks that replaced stock in the back
Firestone airbags with on board compressor
Bushwacker cut out Flares,16.5x9.75 wheels, with 37/12.50-16.5 Goodyear Wrangler MT's
Yukon 4.56 gears with Lockright Locker in the front
Weathermanmc is offline
post #2 of 11 Old 07-08-2009, 05:18 PM
guntersxr's Avatar
didnt pull my cab, yanked the motor
guntersxr is offline
post #3 of 11 Old 07-08-2009, 07:40 PM
semmens21's Avatar
how tough was it to take the motor out and about how long did it take?
semmens21 is offline
post #4 of 11 Old 07-08-2009, 08:13 PM
Hey semmens, If you do a search you will probably find quite a few people have done studs cab on motor in. I am in the process of doing mine right now and had a write up on here with pics and stuff. All in all its fairly easy, if you've done head gaskets in a newer body camaro then your really not that far off. The motor is pretty far back under the cowl, but if you remove the passenger inner fender and the evaporator housing the job is a piece of cake. I have 15 hours into my tear down, the heads are at the machinist as we speak, and am waiting on the new oil cooler from ford once I get the stuff back I will let you know how assembly goes. I figure I wont get everything until next week mon or tues.
mikeproc is offline
post #5 of 11 Old 07-08-2009, 08:31 PM
Redneck47441's Avatar
Quoted: 2 Post(s)
Ya you can cut the firewall alittle and then put epoxy where you cut after the install!
OLD 2006 F-350 CC LB
SCT Tunes Cale, DJ, Spartan & Innovative
bilstien 5100's
fox 2.0 dual steering stabilizer
2" Leveling Kit
35x13.00x18 Nitto A/T
Zoodad, Autometers PhantomII, PTO switch,
Harpoon, 18" XD Diesels
2010 Toyota Tundra
Rock Warrior
Redneck47441 is offline
post #6 of 11 Old 07-08-2009, 08:39 PM
The Lady Mod
Granny's Avatar
Send a message via Yahoo to Granny
Yes they can be done without lifting the cab. We did it and I do not recall having to cut the firewall. If you have access to a lift, it is SOOOOOOO much easier!!!!! We have done the heads both ways and trust me when I say lifting the cab is the way to go, if you can do it that way, but to answer you question, YES, it can be done without lifting the cab.
Granny aka Terri
04 F250 CC 6.0L PSD 2WD
A Few Ponies Under The Hood
Wrenches Turned by Trucks Unlimited (Thanks Scott!) and NPCCPARTSMAN
Injectors by Ryan Casserly of Full Force Diesel
Turbo by KC
Oil Cooler by BulletProof Diesel
SCT Custom Tuning
Granny is offline
post #7 of 11 Old 07-09-2009, 08:29 AM
semmens21's Avatar
alright ill do that. i run eric's extreme race as my daily driver so i need to get some studs soon lol. thanks for the help
post #8 of 11 Old 07-09-2009, 09:43 PM
The Lady Mod
Granny's Avatar
I got pics of the heads being done with the motor coming out the front end and with the cab off. Let me know if you are interested in seeing the difference
Granny aka Terri
Turbo by KC
SCT Custom Tuning
Granny is offline
post #9 of 11 Old 08-05-2009, 08:59 PM
I'd like to see the pictures of the motor coming out the front.
I'd really like to get studs put in my '05, but after reading an article in the latest Diesel Power magazine, it's got me a little worried. It said something in the area of 20+ hours just to lift the cab? I'd assume it would cost substantially less to put the studs in without the cab lift, is that a fair assessment?
Mustang1989 is offline
post #10 of 11 Old 08-05-2009, 09:07 PM
I did my studs with motor in cab on and did a pretty big write up on it here. Its not as bad as its made out to be. I had 30 hours total into my head gaskets and studs along with a new 4in turbo back exhaust egr delete and coolant filter.
Head gasket and stud install
mikeproc is offline
