SCT programming question
What axle/gear ratio do i want to set it at (i have a stock torqueshift) and on the shift pressure what exactly is that and what do yall recommend?
Is the truck shifting to hard for you? Thats what the shift pressure is for. And I am not sure what you are asking about the gear ratio. Are you talking about your tire revs. per mile?
Do not mess with the shifts pressures unless Eric tells you other wise. Ive known folks that dont know what they are doing and mess with that stuff and had the truck run completely odd and shift flares etc etc. Just talk to Eric for that. As for your gear ratio I believe on a stock truck it is 3.73.
iF you have a custom tune then leave the custom programming to the pros. only mess with the shifting if you talk to the tuner first like said above. just tell the tuner everything you have done to your truck and if you get it and its not right they will fix it until it is
