Air Intake or Stock
Hi guys just a question for you, I have a 06 F-350 stock and I have been think of a after market Air Intake over the stock one that the truck has. What are your thoughts? As everyone knows one thing at a time. What is the right one to look at. I am looking to increase the fuel economy and maybe the power. Thanks for your time
I prefer the S&B over any of the rest..you get 8 layers of filtration and its completely reusable (and its one of the cheapest)..all you gotta do it pull it off and clean it and reinstall..after about 40,000 miles the intake will pay for itself, just by not having to buy a new OEM filter each time you need a new filter (going by 10k change intervals) You wont get a bunch of HP from this mod ..and I cant say about fuel mileage..but I like the simplicity of it..plus they look good under the hood.
To the OP: what is your reason for changing out the filter? Use of changing and/or reusing the filter? Filtration or more air flow? The first one is about the only one that has any merit to it, but it would not be worth it to me just for that alone. Filtration of the stock filter is pretty damn good, this isn't the same filter that was on the 7.3. Air flow, while most a/m intakes do flow more then stock, they do not flow more air until you hit very high in the rpms(the quickest is at 3,700 rpm) well beyond the rpm ranges for tq/hp of a stock or tuned 6.0(2,000 and 3,300 rpm repectively). In my opinion, unless you're going to be doing heavy modding, you really do not gain much(if anything at all) with changing out the intake. |
So far I'm sticking with stock. Once I'm getting low on perf mods I'm going to get S&B. unless there is better(filtration%)
See the results for yourself, most testing is done at MAX RPM/HP
ISO 5011 Test Results Certified to the ISO 5011 Air Filtration Standard Testing Conducted Using: AFE 21-40035 (Dry Media) AEM 21-3059DK (Dry Media) S&B KF-1006 (Cotton Guaze) Ford: FA-1750 (OE Filter) http://www.thetruthaboutfilters.com/...andAFE_Dry.pdf |
Once I realize that it was basing it's results for a 7.3 I stopped right there, so the results might be good for that engine, but that doesn't mean that it would carry over to the 6.0. Filtration, rpm ranges, and airflow are different for the air filters on a 7.3 versus a 6.0. Think of it this way, people can get away with inline fuel modules on a 7.3 more often then they could with a 6.0, but they carried over their experience from the 7.3 and look what it got them? Just because it worked better for one engine, doesn't meant that it will for the next. Last edited by tex25025; 06-24-2009 at 04:05 AM. |
Tex, where are you getting your "facts" from?
knowing what i know now, i would've saved that cash for something else. the only difference i've noticed is the turbo is a little louder, especially when it farts after getting on it. this is the one i would do with a stock intake...
![]() 03-07 Ford 6.0L Powerstroke OEM AFE Drop in replacement filter |
Tests that were conducted by AFE and K&N.
What they typically focus on is the fact that they do flow more air(which they do), however, if you look at their graphs you'll see at what rpms that they do flow more and compare that to the the rpms that the 6.0 "works" best at. As to S&B and the fact that their tests do not reflect what goes on with the 6.0, they actually say on their sheet that under truck info it was a '97 Ford diesel. If you look at most of the forums for the 7.3, they will say that the stock filter is a pretty bad one, conversely, if you were to go to the 6.0 forums, they would say that the stock filters are quite good and based on test results from the aforementioned companies, there is some support to that end. |
Everything is stock on my 06 6.0 except the K&N intake and filter. I'm getting 2 mpg more and noticed a considerable gain in throttle response & power. Some say the K&N filter is not good because it lets dust through. I have not had a problem with it and I think most filters do let dust through to some extent.
