05 X no heat - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 03-12-2009, 04:53 AM
05 X no heat
The Wifeys EX suddenly stopped producing heat. Fans all work well A/C works. I reset the computer. Me thinks it is an actuator. anyone agree or disagree? Where is that sucker located?
Old 03-12-2009, 07:27 AM
check the heater control valve under the hood. it is vacuum operated and wont work if the vacuum line falls off like mine did.
Old 02-12-2010, 02:26 PM
Thiis is an old post I realize but had similar problem with our X. No heat front or rear in Utah in December. Chilly ride. Fix was vehicle had run low on antifreeze probably from hot summer to cold winter. Filled overflow plus some, and immediately started getting heat in both front and back. Could be unrelated flook but it fixed mine hopefully it helps.
Old 02-15-2010, 06:16 AM
Make sure you have enough coolant/Water in your system.
Let the truck run at Idle for 20-30 minutes with the reservoir cap off and see what it does.
Had a no heat issue and this fixed it. Its a free thing so no point in not trying.
Old 02-17-2010, 03:25 PM
First 6.7 PS Destroyer
or your head gaskets are blown again... like mine.
Old 03-10-2010, 03:41 PM
2nd the blown headgasket, mine as well, additional coolant did help get some heat going.
