Wheel Question? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 02-05-2009, 06:28 PM
Wheel Question?
i have read on here that newer model wheels will fit on older model trucks but the newer wheels won't work on the older ones. is this true? i have a 03 X and want to put a set of newer 20in stock wheels on it. is there anything that can be machined? or modded to make this work?
Old 02-05-2009, 06:51 PM
They won't fit, they'll rub the leaf springs! You could put a spacer behind it, but you would be better off buying a set of 20's that will work right on your truck. Just my
Old 02-05-2009, 06:57 PM
I have them on mine, and i got an 04. They will rub, but i bought the 1/4 inch spacer plates. That took care of the rubbing. Oh yea by the way i have 20's. 275/75/20 tires. And those are equiveilent to 34's, without a leveling kit.
Old 02-07-2009, 01:13 PM
When I do the conversion for those tires i get 275/25.4 = 10.83 inch wide tire 10.83 * .75 gives me 8.1 inches of side wall height.... 8.1*2 then add 20 and i get 36.2 inch tall tire. Did I do the conversion right??? If so that not a 34" tire...one of the number has to be off somewhere...im willing to bet if u say its a 34 inch tire thats a 275/65.
Old 02-07-2009, 01:15 PM
Feedback Score: 5 reviews
I'm pretty sure he meant 275/65R20 BFG makes a 285/65R20......
Old 02-08-2009, 10:34 AM
Has anybody installed 20x10 and 35" 12.50 inch tires on stock suspension ?
