excursion lift questions - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 06-16-2014, 12:24 AM Thread Starter
dayne808's Avatar
I have an '05 limited with a 6" pro comp lift. the code on the front leaf springs is 22410 which is a 4" lift leaf spring. I thought it was weird and I'm a little confused. is there a reason why they use the 22410 spring in their lift that's advertised as a 6" kit? I want to add more lift so im wondering if I can put in the 22610 spring which is listed as a 6.5" lift spring for a f250/f350?
2005 Excursion LTD
6" procomp lift
SCT livewire
4" MBRP exhaust
sinister egr delete
dayne808 is offline
post #2 of 3 Old 07-06-2014, 05:25 PM
Excursions net out 2" more then the same spring on the trucks. If you switch lifts and want to sell it shot me a price.
2003 Excurstion
6.0L 120xxx miles
EGR Delete
ARP head studs
6" BDS suspension with 20x12 -44 with 325/60R20s
UnlimitedLove is offline
post #3 of 3 Old 07-06-2014, 07:24 PM Thread Starter
dayne808's Avatar
Gonna swap out the front springs for the truck springs cause mine are sagging then I'm gonna put a 6" block in the back cause there's 2 2.5" blocks stacked just need a couple more inches for clearance
2005 Excursion LTD
6" procomp lift
SCT livewire
4" MBRP exhaust
sinister egr delete
dayne808 is offline
