Clunk while accel/decel - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 06-14-2014, 03:50 AM Thread Starter
Moungo's Avatar
My 05 4x4 ex is completely stock with 138xxx miles is giving me a "clunk" you can hear/feel... most noticeable at highway speeds when you let off the pedal and press it... sounds like the driveshaft has play... I did some research and found a bunch of stuff about greasing the slip yoke splines but if I understand correctly thats just for two piece drive shaft mine is a single... it also gives me a slight 1 second vibration on decel as well... my theory is ujoints... just wanted to see if anyone else had a similar issue... I hate throwing parts at vehicles...
Moungo is offline
post #2 of 4 Old 06-14-2014, 07:57 PM
I'm having a similar sensation. I'm curious what people have to say!
John In Canada
2005 6.0L Excursion
JohnInCanada is offline
post #3 of 4 Old 07-08-2014, 07:56 AM
Maybe suspension related? Drop the front anti-sway bar and see if the issue persists. I replaced the sway bar connecting arms (correct term?) when I got my '05 with 118k to solve a clunk.
At 140k miles now, I am curious about the stock ujoints (rear propeller/drive shaft) that don't have grease fittings. Any information on how long these typically last?
2005 Excursion Engine: EGR/CAT Delete, Innovative ECM Tune, PHP FICM Tune, coolant filter, stock TTY head bolts and Ford Gold Coolant. Suspension: Bilstein shocks; V Codes springs on front; RAS and Air Lift airbags over stock rear springs.
mmuthart is offline
post #4 of 4 Old 07-08-2014, 08:31 AM
sbluke55's Avatar
Quoted: 591 Post(s)
Garage
One piece drive shafts still have slip yokes. It's easy to test u joints. Block the tires, put the truck in neutral, grab the one yoke with one hand and the other one with the other hand. Then move your hands in opposite directions. Kinda like giving a Indian burn. If you feel any play they are bad.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
