Calculating Mpgs - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 1Likes
post #1 of 17 Old 06-10-2014, 10:41 AM Thread Starter
darkpassenger's Avatar
Quoted: 808 Post(s)
Calculating Mpgs
I would like to know the best way to calculate mpgs .Maybe something that uses gps.
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #2 of 17 Old 06-10-2014, 10:50 AM
Heavy_GD's Avatar
Quoted: 1494 Post(s)
Feedback Score: 3 reviews
Step 1. Filling the vehicle's gas tank completely and writing down the vehicle's odometer reading (mileage). Example: The last time the tank was filled, the odometer reading was 32,645.1 miles.
Step 2. When it's time to refuel, filling the tank completely and writing down the number of gallons it took to fill the tank and the vehicle's new odometer reading. Once two odometer readings are taken, MPG can be calculated. Example: The next time the tank was filled, the odometer reading was 33,001.3. It took 13.5 gallons to fill the tank.
Step 3. Calculating the distance driven by subtracting the previous odometer reading from the new one. Example: The distance driven would be 33,001.3 minus 32,645.1, or 356.2 miles.
Step 4. Dividing the number of miles driven by the number of gallons it took to fill the tank. The result is the vehicle's MPG for that driving period.
Example: 356.2 miles divided by 13.5 gallons equals 26.4 miles per gallon.
The MPG for that driving period would be 26.4.
GD
Heavy_GD is online now
post #3 of 17 Old 06-10-2014, 11:51 AM Thread Starter
Quoted: 808 Post(s)
OK I've been doing that but I have a feeling it's wrong as I have 33 inch tires.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #4 of 17 Old 06-10-2014, 05:22 PM
Heavy_GD's Avatar
Haha, that detail is important.
I have a speedo corrector, but I'm not sure 33s will throw it off that far
GD
post #5 of 17 Old 06-10-2014, 06:52 PM Thread Starter
Quoted: 808 Post(s)
What's a speedo corrector? Where do get it?
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #6 of 17 Old 06-11-2014, 09:19 AM
KyleQ's Avatar
That options works well, but I really don't want to fill the tank on my Excursion every time to figure out the actual MPG. Although that is the best way to figure it out -
Torque gives MPG readings based off the distance traveled and the amount of fuel used. I don't know if it reads off the gas gauge level or if it reads how much fuel is actually being used by the engine.
64' Galaxie 500 - 352/Cruise-o-Matic/9"
66' Mercury Monterey 390/C6/9"
74' Bronco - EFI 351/NP435/AtlasII - D60/D70 Full Hydro Steering - 43" TSL SXII on H1 Beadlocks
74' Bronco Ranger - EFI 351/NP435/NP205 D44/9"
86' F350 - 6.9idi/T-19 -2nd Tow Pig
96' Bronco - 5.0/E4OD/1356 Plow Truck - Aussie locker/Trac-lok
03' 6.0 4x4 Excursion - Sinister Coolant Filter / Sinister EGR Delete
08' Focus Coupe - the DD
KyleQ is offline
post #7 of 17 Old 06-11-2014, 04:18 PM Thread Starter
Quoted: 808 Post(s)
You mean torque the app right I tried it out once but didn't get to far (since I have scan gauge) might have to give it another try. Any tips on configuration?
I remember having some trouble.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #8 of 17 Old 06-11-2014, 07:15 PM
KyleQ's Avatar
Torque makes a scanguage worthless - just create a profile with the correct info and you are set. I nearly bought a scanguage, but I'm glad I didn't - only thing I can't really monitor are EGT's, but on a stock truck I've got no worries anyway.
KyleQ is offline
post #9 of 17 Old 06-15-2014, 08:15 PM Thread Starter
Quoted: 808 Post(s)
Yeah while I see what you mean my truck is tuned and I like to play music of my phone and do other things so while it's a good choice. Scan gauge 2 is a good tool and I can't see myself jus using my phone as I like to have constant monitoring (kinda paranoid I might flip to music and my Temps skyrocket as it happend when my radiator hose broke lol
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #10 of 17 Old 06-16-2014, 07:00 AM
KyleQ's Avatar
Torque will stay running and displaying with music functioning in the background... unless you need to see the track information and artwork. There are a TON of pre-programmed PID's in Torque and it works really well.
KyleQ is offline
