Torque app latest update 1.8.38 - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 06-04-2014, 04:22 AM Thread Starter
So apparently when the latest Torque update was pushed last night, it broke lots of things. I am no longer getting EOT pids, load, etc. I tried removing and readding the pid list and no luck. I am also getting some strange connection error with the obd2 adapter now. Anybody else encounter this?
hpgkmc is offline
post #2 of 4 Old 06-04-2014, 07:01 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
Are these automatic updates to the app? If so, mine worked fine at 6:30 this morning. Same as always. Taking lunch in an hour, i'll see if it's any different then.
2005 Excursion Limited w/254K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is offline
post #3 of 4 Old 06-11-2014, 09:33 AM
KyleQ's Avatar
Mine worked fine yesterday... I watch OET, ECT, FCIM Voltage, Batt Voltage, MPG, Trans Temp all without issues.
64' Galaxie 500 - 352/Cruise-o-Matic/9"
66' Mercury Monterey 390/C6/9"
74' Bronco - EFI 351/NP435/AtlasII - D60/D70 Full Hydro Steering - 43" TSL SXII on H1 Beadlocks
74' Bronco Ranger - EFI 351/NP435/NP205 D44/9"
86' F350 - 6.9idi/T-19 -2nd Tow Pig
96' Bronco - 5.0/E4OD/1356 Plow Truck - Aussie locker/Trac-lok
03' 6.0 4x4 Excursion - Sinister Coolant Filter / Sinister EGR Delete
08' Focus Coupe - the DD
KyleQ is offline
post #4 of 4 Old 06-11-2014, 01:05 PM
Vannnce's Avatar
Quoted: 13 Post(s)
It'll update based on your phones settings i believe. My phone will only update when it is connected to my home wifi. Not sure how your guys are set up
But with that said, im keeping tabs on this thread to see what happens. OP, that sucks man hopefully it gets fixed
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
