Will EGR delete throw a CEL in 2004.5 (March 2, 2004) Excursion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 8 Old 05-17-2014, 06:12 PM Thread Starter
I am getting ready to install an EGR delete in my truck along with a new oil cooler and coolant filter.
I will be flushing with Restore and Restore+ and going with ELC instead of the Ford gold that is in it now.
Truck is new to me and bone stock.
I am not running any tunes (no tuner budget).
My EOT and ECT run about 8-10 degrees apart now, even on 90 degree Texas days.
Thanks for the insight. I have read that Excursion's sometimes got older parts and engines than regular Super Duty trucks.
2004 Excursion 6.0L Eddie Bauer 2WD
Oxford White / Arizona Beige Metallic
136K and counting
Fresh out of the box - stock
18" Lariat 6 Spoke Wheels (in garage til I get wheel spacers)
2009 Escape Hybrid
Black Slate Metallic
Totally Stock
56K and Climbing
2014 Freedom Express 292BHDS
7700 lbs on Reese WD Hitch
Sold
2003 Excursion 5.4L 2wd XLT
Red Fire Metallic / Gray
Gray Cloth Interior
KC0EJX is offline
post #2 of 8 Old 05-17-2014, 06:22 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
It will not throw a code. But if at all possible I would love to talk you out of doing a coolant flush on your system. What you are gonna do is break loose all the tiny pieces of junk and then turn your oil cooler into a coolant filter. I would bet you a $100 if you do the flush your delta's will go outta site.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 8 Old 05-17-2014, 06:37 PM Thread Starter
I am trying to get the truck ready to pull my 32 ft 7800 lb trailer to Canada in late June. Everything I read says to ditch the Ford gold and use a Cat approved ELC.
Should I just do a swap with the distilled water and no Restore? Once I have run 16 gal thru then go back w/ ELC?
136K and counting
2009 Escape Hybrid
Totally Stock
56K and Climbing
Sold
Gray Cloth Interior
KC0EJX is offline
post #4 of 8 Old 05-17-2014, 06:41 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What I would do is install a coolant filter first off. Drain the old Ford Gold out and replace with fresh Ford Gold. Its reeley not bad coolant if changed out in suggested times. The system is running fine and s long as it is maintained you've got time on the clock. Yes your gonna have to keep a eye on it but depending on maintenance and miles it could be way down the road before you need to go deep into it.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 8 Old 05-17-2014, 06:44 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would be more concerned about stuff like your oils,blue spring upgrade, manual fan control or even the Bullet Proof Diesel 7.3 fan clutch mod, your ficm health...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 8 Old 05-17-2014, 07:18 PM
Quoted: 48 Post(s)
this man's giving you good advice
all too often doing a hard flush causes a lot more grief than just draining and refilling with Gold. If your temps/deltas are good, I would just put fresh gold in it and roll on
drunk on diesel is offline
post #7 of 8 Old 06-21-2014, 10:16 AM
I avoided an egr code when I did the egr cooler delete in my truck. I just left the egr in there and left it plugged in. It's only opening and closing like it did before. It just doesn't have any exhaust gas going through it anymore.
04 F-350 Single Wheel 4X4
05 Excursion
2000 VW Golf TDI (dead)
Joe Kelsch is offline
post #8 of 8 Old 06-21-2014, 10:21 AM
Quoted: 48 Post(s)
you can't avoid a code like that on an 04.5+ truck. you will get a CEL for EGR Flow Insufficient
