Puking coolant - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 16 Old 04-27-2014, 07:54 AM Thread Starter
darkpassenger's Avatar
Quoted: 781 Post(s)
Puking coolant
I changed the cap early on( 2 months ago) after viewing the Powerstroke help video on YouTube, got the one from advance auto parts . And issues started just recently. Went to try and get another they did not have, my deltas are way below 15. Just to knock that out. What else could it be and what is the simplest way to diagnose this issue.
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #2 of 16 Old 04-27-2014, 08:40 AM
Term3's Avatar
Puking coolant
Most likely head gaskets. Put a pressure gauge on the cooling system and if the pressure climbs fast under hard acceleration you've confirmed it. Just make sure you get the heads decked and only use OEM head gaskets. Toss the OEM head bolts in the scrap metal bin and get some ARP studs.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 16 Old 04-27-2014, 08:43 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Go to ford and get an OEM cap. The Stant caps suck
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 16 Old 04-27-2014, 08:44 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
But also do what Term said and pressure test the system
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 16 Old 04-27-2014, 09:09 AM Thread Starter
Quoted: 781 Post(s)
That I was planning on doing plus getting the bullet proof oil system, saving up.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #6 of 16 Old 04-27-2014, 09:10 AM Thread Starter
Quoted: 781 Post(s)
Where do I get the gauge? How is it done exactly?
I'm planning on bulletproofing and studing and etc etc in a couple of months.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #7 of 16 Old 04-27-2014, 10:19 AM
Term3's Avatar
Just "T" into the small hose going into the degass bottle and get a cheap 0-20 psi (cap relieves at approx 15 psi) mechanical gauge from a local hardware or auto parts store. I just ran a long hose from the "T" out from under the hood and tie-wrapped the gauge to my windshield wiper. It ain't pretty but it gets the job done.
Term3 is offline
The Following User Says Thank You to Term3 For This Useful Post:
darkpassenger (04-27-2014)
post #8 of 16 Old 04-28-2014, 04:45 AM
johnnybgood's Avatar
Quoted: 78 Post(s)
It's a longshot but maybe you just had to much coolant in? Was it at or maybe above the full line?
johnnybgood is offline
post #9 of 16 Old 04-28-2014, 04:56 AM Thread Starter
Quoted: 781 Post(s)
It initially was after my radiator hose had broken, and I refilled, but now it seems to be at level and still doing it also I recalled it happened before my hose issue. I tightened it alot yesterday and while I still had some puking not as much. I wonder how good would an oem cap and if it would be a revised one because I know the original caps had issues holding pressure.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #10 of 16 Old 04-28-2014, 05:32 AM
Quoted: 78 Post(s)
I've heard on here that ford changed the new full mark to the old low mark. Mine sits just above the low mark usually. Been that way since the new radiator went in. Mechanic drained and added new coolant and that's where he put it.
The Following User Says Thank You to johnnybgood For This Useful Post:
darkpassenger (05-25-2014)
