Truck struggles to turn on and stay on. - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 1Likes
post #1 of 14 Old 04-19-2014, 01:33 PM Thread Starter
darkpassenger's Avatar
Quoted: 808 Post(s)
Today it has been 2 months with my ex minor issues here and there . Newest issue is it struggles to turn on and once on struggles and won't go faster than like 15mph till it fully warms up. Even then after its warmed up I can note a small intermittence as if the engine hesitates for a slight fraction of a second. All suggestions welcome.
Here is a video of it right after its turned on.
Excursion 2003 6.0 struggling to stay on.: Excursion 2003 6.0 struggling to stay on. - YouTube
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is online now
post #2 of 14 Old 04-19-2014, 02:02 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
whats your ficm voltage??
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
The Following User Says Thank You to 6.0newb! For This Useful Post:
darkpassenger (04-19-2014)
post #3 of 14 Old 04-19-2014, 02:15 PM
strokersixo's Avatar
Quoted: 32 Post(s)
X2,
Check the ficm voltage, below 45v and you've got a bad ficm 48v is an ideal voltage.
--MAX--
strokersixo is offline
The Following User Says Thank You to strokersixo For This Useful Post:
post #4 of 14 Old 04-19-2014, 04:02 PM Thread Starter
Quoted: 808 Post(s)
Thanks im at work now will check when I get out and update.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #5 of 14 Old 04-19-2014, 09:44 PM Thread Starter
Quoted: 808 Post(s)
It's bad. Got out of work and powered up. Programed the pids. And I saw it in the 30s then after a while I went up to 40-48. Guess I need a new one is it hard to install? And which should I get?
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #6 of 14 Old 04-19-2014, 09:49 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
It's a piece of cake to install so no worries there. I personally recommend the bulletproof diesel unit but they are kinda pricey. If you need to go the cheaper route ed at ficmrepair.com has a pretty good reputation on here.
6.0newb! is offline
post #7 of 14 Old 04-19-2014, 10:07 PM Thread Starter
Quoted: 808 Post(s)
Hmm I like the fact that the ones from ficm repair come tuned and a lifetime warranty for half the price sounds good Thanks gonna have to call this dude up.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #8 of 14 Old 04-19-2014, 10:14 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
For sure. And I could be wrong but I think a tune on the ficm costs extra...? On the bpd unit, you can select the voltage as well as a couple other neat features
6.0newb! is offline
darkpassenger (04-20-2014)
post #9 of 14 Old 04-20-2014, 03:34 AM Thread Starter
Quoted: 808 Post(s)
Yeah its 150 + 425 (ultra) with lifetime warranty that means I'll never have to worry about buying another one. That's good!
strokersixo likes this.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #10 of 14 Old 04-20-2014, 05:50 AM
Quoted: 2 Post(s)
Be sure to have your batteries individually tested as well as your alternator. Bad batteries can cause false low voltage ficm readings and cause damage to the ficm.
2007 F250 Lariat FX4 CCSB
200,000+ Miles
SCT Livewire TS
Innovative Xtreme Street
Barder Stg 1.5
Arp Studs, Sinister EGR Delete
cudakid03 is offline
