BRAKING! BRAKING! BRAKING! - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 15 Old 04-17-2014, 12:10 PM Thread Starter
Hello everyone. I've been reading great content on bulletproofing, suspension, towing, tires, etc. But little discussion about braking.
SO. What's the best setup for braking with an Excursion?
For myself, I'm wanting to turn my '05 Excursion 6.0L into the ultimate towing monster. I'll be taking Cary's advice on suspension upgrades, doing a full bulletproof of my 6.0L PSD, and putting the best tires I can find.
Now to make some decisions on the brakes. There's got to be some significant improvements I can make. What are your thoughts?
John In Canada
2005 6.0L Excursion
JohnInCanada is offline
post #2 of 15 Old 04-17-2014, 12:13 PM
dieselmatt's Avatar
Quoted: 3 Post(s)
I'm curious as well since I need new rotors and pads.
dieselmatt is offline
post #3 of 15 Old 04-17-2014, 12:43 PM
Raul@Stealth Automotive's Avatar
are you looking to stay with stock components? or if you want the biggest of the baddest SSBC makes a nice big brake kit for your truck
Raul@Stealth Automotive is offline
post #4 of 15 Old 04-17-2014, 01:04 PM
crash&burn's Avatar
x SSBC great products I have their rotors and brake pads
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #5 of 15 Old 04-18-2014, 09:58 AM
Term3's Avatar
THE biggest AND baddest would be Wilwood brakes but you need 20" rims to make room for them. Braking performance is UNBELIEVABLE.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 15 Old 04-19-2014, 06:49 AM Thread Starter
I'm currently wearing 18's on the truck. New tires and rims is a cost I'd like to avoid... Any suggestions that would fit in 18's?
John In Canada
2005 6.0L Excursion
post #7 of 15 Old 04-19-2014, 08:41 AM
Term3's Avatar
SSBC V8 calliper swill fit.
Term3 is offline
post #8 of 15 Old 04-19-2014, 09:42 PM Thread Starter
Term3, are there any performance numbers that explain the SSBC? It's a hefty price to pay without some proof!
John In Canada
2005 6.0L Excursion
post #9 of 15 Old 04-20-2014, 07:26 AM
Term3's Avatar
I know one guy that has SSBC V8 calibers and he found it made a big difference in stopping his big, lifted truck. It's basic physics, the more friction surface the better the stopping power. Keep in mind OEM rotors aren't up to the task, cryogenic treated, drilled are pretty much mandatory as the OEM rotors will warp.
Term3 is offline
post #10 of 15 Old 04-29-2014, 11:32 AM
Todd TCE's Avatar
Quoted: 2 Post(s)
Actually...pad size is not torque. Frictional force is pressure times Cf. In short; a larger pad does not make more braking "power"- pressure applied being equal. Think of standing on a scale with shoes that are to large: you weigh the same. That's force applied.
Larger pads become necessary when more or larger pistons are in play necessitating the load be applied over a greater area.
However changing a pad Cf from .38 to .55 would create a huge torque change even with the same pressure or area being used.
Your one stop...for Wilwood brakes.
Todd TCE is offline
Tags
braking , excursion
