Just purchased an 03 Excursion... - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 04-14-2014, 06:30 PM Thread Starter
I just bought a really clean 03 Ex eddie bauer edition w/ 133,000 miles on the clock. Original owner has done alot of stuff.... new injectors, oil cooler, egr. New tranny. He also installed a rancho lift... 4" i believe. 315/75/16 nitto terra grapplers The front shocks are toast. Been trying to decide which to replace all four with. It has rs9000xl i believe.. they're the adjustable ones. 'Ive run bilstiens on all my dodges. which is best?
I replaced the stock exhaust with a 4" tbe. Changed oil w/ rotella 5w-40 synthetic, added archoil 9100, changed oil filter and fuel filters with Motorcraft and Racors.
Just ordered a sct programer, sinister egr delete kit, oil cooler coolant filter kit. Intake gasket set. turbo bolt w/ o-ring. updated turbo feed line. blue spring upgrade kit. stc hpop update kit. oil drain tube. 04-07 factory stand pipe. degas bottle cap. dummy plug.
May pull heads and replace gaskets and install arps.
What am i missing? Im not gonna go wild on programmer either.... may get a ficm. Which is better? 48v stock or somehting in the 53-58v range?
slick willis is offline
post #2 of 4 Old 04-14-2014, 06:52 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
You bought an 03 EX, and go buy standpipes for an 04-07 and an STC fitting that doesn't exist on your truck?
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 4 Old 04-14-2014, 06:59 PM Thread Starter
Came as a package deal off another forum... I knew there was stuff i needed and didnt need.
post #4 of 4 Old 04-14-2014, 07:01 PM Thread Starter
What i dont need i figured i`d sell.
