theft light flashing fast - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 04-13-2014, 04:00 PM Thread Starter
04 ford excursion the theft light is flashing fast then truck shuts off rest the theft system then started up flashed again then shut off started drove 3 miles worked fine has been work fine but then flashed fast again shut off started right back any ideas what could be never had an issue ever just when I sold it yesterday this happend to the new owner... had it for 6yrs not issue help please..
Fountainkid101 is offline
post #2 of 4 Old 04-26-2014, 12:06 AM
Try a different key. It may be the transponder chip.
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #3 of 4 Old 04-27-2014, 06:50 AM
darkpassenger's Avatar
Quoted: 808 Post(s)
Mines does it all the time after installing Clifford alarm, but works fine ask him if he added and alarm. Or anything else he might have added
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #4 of 4 Old 04-27-2014, 07:57 AM
Term3's Avatar
Could try disconnecting BOTH batteries then touch the positive and negative cables together to drain any residual power which may reset the memory. This worked on my Ex when my remote start/alarm system would lock all the doors each and every time I opened and closed a door.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
