Engine Oil Temp At 300° - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 18Likes
post #1 of 96 Old 04-13-2014, 11:57 AM Thread Starter
darkpassenger's Avatar
Quoted: 801 Post(s)
Out with the family and upon after stopping at a sonic drive in to eat car idle for about 30 mins temp started shooting upwards to 300°
I pulled into a walmart I know I needed to add some oil cuz when I checked this morning it was a little low almost a quarter. I'm gonna get some Rotella t6 but I fear it may be a coolant issue as the reservoir seems to have been releasing some. So I don't think Walmart has ford Gold what should I do?
I'm kinda stranded here with wife in law and 5 kids.
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #2 of 96 Old 04-13-2014, 11:58 AM Thread Starter
Quoted: 801 Post(s)
Here is a pic
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #3 of 96 Old 04-13-2014, 12:05 PM
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
How are you reading a 300 degree oil temp?
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #4 of 96 Old 04-13-2014, 12:12 PM Thread Starter
Quoted: 801 Post(s)
Scangauge 2
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #5 of 96 Old 04-13-2014, 12:15 PM
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
What was your coolant temp?
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #6 of 96 Old 04-13-2014, 12:21 PM Thread Starter
Quoted: 801 Post(s)
When I last checked it 213 while idle
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #7 of 96 Old 04-13-2014, 12:24 PM
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
if your oil was at 300 and your coolant was at 213 you oil cooler is shot. which would explain the coolant puking from the degas bottle. I have experienced this with my truck a few years ago. How far away from home are you?
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #8 of 96 Old 04-13-2014, 12:26 PM Thread Starter
Quoted: 801 Post(s)
About 36 miles as per gps, actually I just found the culprit the radiator hose is broken.
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
post #9 of 96 Old 04-13-2014, 12:32 PM
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
anything above a 12 degree difference between oil and coolant temp indicates a plugged oil cooler. You can watch your temps like a hawk and drive home if you get anywhere above 260 oil temp pull over, let it idle a bit or shut it down and wait till it goes back down. Basically limp it back home. Be very careful doing this!!
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #10 of 96 Old 04-13-2014, 12:34 PM Thread Starter
Quoted: 801 Post(s)
I knew it had a crack in it but was going to fix it this week can I add water and duct tape it just to get home
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
