05 Excursion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 10 Old 04-08-2014, 10:12 AM Thread Starter
05 Excursion
Greetings:
I've found an 05 Excursion with an 09/05 build date. Would this be one of the last Excursions built? Does anyone know when the last build date would have been?
Also, since it has a September build date, would this Excursion have the best bullit proofing from Ford?
Thanks.........
Swmpbgy1
swmpbgy1 is offline
post #2 of 10 Old 04-14-2014, 08:55 AM Thread Starter
No one??????
swmpbgy1 is offline
post #3 of 10 Old 04-14-2014, 10:46 AM
Tattooz's Avatar
Quoted: 2 Post(s)
Last one made was sept 30 at the Louisville plant
2004 Excursion
Leveled front, block rear, FUEL OCTANE 20's,Nitto Terra grap's 295/60/20,Tint, Edge CTS, Diamond eye Turbo back stainless 4inch pipe with muffler, 6.0 GONE ~ CUMMINS in !!!!
2011 Crew long bed King ranch 6.7 Mini Maxx,No Limits full Delete, S&B CAI, 6 inch pro comp lift, XD wheels, Toyo R/T
37x13.50x20
Tattooz is offline
post #4 of 10 Old 04-14-2014, 10:47 AM
Tattooz's Avatar
Quoted: 2 Post(s)
I would say yes that one is dang close
2004 Excursion
37x13.50x20
Tattooz is offline
post #5 of 10 Old 04-14-2014, 11:11 AM
Heavy_GD's Avatar
Quoted: 1638 Post(s)
Feedback Score: 3 reviews
05 would not the best bulletproofing, no.. but the best excursion, possibly.
What day was yours built?
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #6 of 10 Old 04-16-2014, 06:49 AM Thread Starter
I haven't purchased it yet.........but the white sticker that shows the vin and build date shows a date of 09/05.....is there a way to determine the actual day it was built on??
I was under the impression that the latest 05's had the most up to date changes to remedy the problems of the 6.0....am I wrong? I'm not going to tune the truck if/when I purchase one, I will tow a 4000lb camper and haul the family on vacations......Probably less than 5000 miles per year will be put on it. Should I steer clear of the 6.0 and look for a 7.3?
Swmpbgy1
swmpbgy1 is offline
post #7 of 10 Old 04-16-2014, 07:45 AM
Heavy_GD's Avatar
Sorry, I miss read that, I thought you had the date.
Not trying to derail your thread but the argument could be made that the late 06-07 engines were the best as they were being prepped fro the changes in 08.
But like I said the Ex only went to 05 so that would be the best.
GD
...because Patriot.
Heavy_GD is offline
post #8 of 10 Old 04-18-2014, 06:01 AM
Quoted: 3 Post(s)
I've also got a Sept 05 build date. You'll need to deal with the STC fitting, and it would be a good idea to replace the plastic CAC tube with the earlier metal style.
2005 Excursion Limited 6.0L 2wd
Atlas 40, Bulletproof EGR cooler, coolant filter, 6.4L banjos, Cat coolant, Gogo direct solenoid, 7.3 fan clutch. Otherwise, all stock.
bigric is offline
post #9 of 10 Old 04-18-2014, 09:12 AM Thread Starter
Well.....the 05 got away from me. Someone has beaten me to the purchase twice now on 2 really nice 05's. At this point.....I'm torn between a low mileage 05 6 liter or hold out for a low mileage 7.3.
swmpbgy1 is offline
post #10 of 10 Old 04-18-2014, 09:36 AM
Quoted: 3 Post(s)
I gave up trying to find a 7.3. They either had 300k on them already, or they thought they were made of gold.
bigric is offline
