Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Ford Excursion Discussion
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 11-28-2008, 06:20 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
over axle piece
the story starts here
where the !@#$ did it go
well when i that happened i just have hadit dumped at the down pipe, i have a full exhaust system from the turbo to the muffler delete pipe
my question is will a 250/350 over the axle exhaust piece work on an excursion
and if so
i was wondering would anyone who maybe went from a 4" turboback exhaust to stacks be willing to part with that piece
Old 11-28-2008, 06:40 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
It should work buddy. I mean it is just a piece of exhuast pipe bent to get over the axle.
Old 11-28-2008, 06:43 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Should work, and If I had that piece still i'd give it to you.. threw all that stuff away when I put the stacks on.
Old 11-28-2008, 06:44 PM
Tournaments Won: 1
the only concern i have is the fuel tank is as big as a piece of dang plywood other than that i dont see a problem
Old 11-29-2008, 07:55 AM
william_04_x william_04_x is offline
i'm sure you saw this thread...in post #5 a guy says the X exhaust is different...IDK...
can't believe someone stole your exhaust...
Old 11-29-2008, 08:22 AM
Tournaments Won: 1
i believe its different but what part is different?
Old 11-29-2008, 08:28 AM
nsrchofpwr nsrchofpwr is offline
lifetime member
all of the axle and wheel well area should be the same. the length in other areas is probably different. hope this helps.
Old 11-30-2008, 06:36 PM
nvrdun nvrdun is offline
I think the tailpipe section is diff in order to clear that big arse fuel tank, but I dont know how diff they are. Might be able to make it work?
Old 11-30-2008, 06:46 PM
Tournaments Won: 1
thats what i was thinking..........and hoping
Old 11-30-2008, 06:54 PM
taylorking taylorking is offline
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
it should work. make sure the position of the hangers are in the same place as the ex's and f series trucks though.
but hey, thats how i got my 4" exhaust...CHUCK got 6" mitres for his rig, and gave me the rest of his 4" system. starts right before the end of the cab, still sounds awesome though
