06 20 in wheels on Excursion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 12 Old 03-26-2014, 02:54 PM Thread Starter
Anyone done this on here? I know I have to have spacers which I have already ordered. What size tires can I run? Truck is stock height, not interested in lifting it. Any help is greatly appreciated
kyle23462 is offline
post #2 of 12 Old 03-27-2014, 11:34 AM Thread Starter
How about a set of 18's then?
post #3 of 12 Old 03-28-2014, 12:28 AM
Many here have put 05+ factory 20" wheels on. There lots of threads here on it. Use the forum search and you will see.
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #4 of 12 Old 03-28-2014, 06:45 AM
Term3's Avatar
Cary at CT Performance (Excursion expert) told me that OEM 20" need 2" spacers or if you cut the studs down you can use 1.5" spacers. I'm hunting for OEM 20" locally right now for my Excursion. Next on my wish list is '08+ axles for bigger brakes.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 12 Old 03-28-2014, 07:59 AM Thread Starter
I decided to go with 18 in Lariat takeoffs, I ordered 2 in spacers already. According to what I found the 99-03 Ex's have 2 in studs and the 04-05 Ex's have 1.5 in studs. A 2 inch spacer is required for all years. I shouldnt have to grind studs at all but we will see once they get here. I will post updates as I go along
post #6 of 12 Old 03-28-2014, 08:39 AM
johnnybgood's Avatar
Quoted: 78 Post(s)
I just tested out a set of 18'' lariat wheels (275/70/18 I think) on my X. No spacers, no lift, 2wd. 2 days of driving. A little rubbing when parking but none when turning on the streets.
Maybe I borrowed a bad set.... the offsets are different then the stock 16s I guess and the wheels looked sucked in to much for me. Driver side looked almost flush, BUT, the passenger side front wheel look like it was sucked in half an inch more then the drivers side. They didn't drive as nice as my stocks either. They may have just been way out of balance, and worn tires, but the truck would pull hard to the left with the Lariat wheels, not at all with the stock 16's though.
And the 5 spoke Lariat 18's each weigh 4 lbs more then the stock excursion 16's I have.
2005 Excursion Limited w/254K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is offline
post #7 of 12 Old 03-31-2014, 03:15 PM Thread Starter
Here is a test fit pic. 275/65/18 Terra Grapplers. 2 inch spacers, no trimming of factory studs. Wheels stick out about 1/4 inch past factory. Will finish the install this weekend
post #8 of 12 Old 03-31-2014, 08:26 PM
darkpassenger's Avatar
Quoted: 781 Post(s)
Nice truck looks as if it was lifted
Excursion 2003 Eddie Bauer 4x2
HidFog Kit 13" 50" led Curved
Kc Stage 2
4 inch Turboback
Egr Gone
58V Fcm
Leveled
33s
Srlxx
Studded Hgs Bulletproof Hd Oil Cooler Etc By Sean Aka Ricmiester at Lox Dce
Blue Spring mod and too much more to mention.
darkpassenger is offline
post #9 of 12 Old 04-01-2014, 12:37 AM
Looks good! the 20" wheels that are late model take offs are 34.1 inches tall and look a bit big even with the V\B spring change.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #10 of 12 Old 04-02-2014, 03:31 AM Thread Starter
These are the 18" Tom. I had a set of 20" and traded them for the 18". The only thing I do not like about them is the gap between the locking hub and the center cap. I may try and find a rear set of center caps for the front so you cant see it. I always keep my hubs in auto anyway. Hopefully the weekend weather cooperates and lets me finish the install. Now to decide if I keep the factory 16's or sell them.
