Excursion body mount replacement - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 13 Old 03-05-2014, 04:27 PM Thread Starter
I talked with Sunrise Ford today and it looks like most Excursion body mounts for earlier (2002) and several later (2005) are now discontinued.
Does anyone know if the 2004 F350 mounts will work. Ford has different color codes on the mounts that are related to how stiff the material is. I think they are dimensionally the same. If you know about mounts that will work please let me know. Thanks!
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #2 of 13 Old 03-05-2014, 04:36 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
There is a member here that builds new Excursions by marrying them to new trucks. Click me to check out one of his build threads. He would know probably better than anyone else here. Try sending him a PM.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 13 Old 03-05-2014, 04:45 PM Thread Starter
Thanks! I sent him a PM about this thread.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #4 of 13 Old 03-14-2014, 11:35 PM Thread Starter
Will be trying the Daystar F350 body mounts soon.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #5 of 13 Old 03-16-2014, 06:38 PM
pdombrowicki's Avatar
You can get some of the F250 mounts. We reuse the old ones because we can't get new ones.
2008 F350 6.4l Powerstroke Larriet CC, LB
Harley grille,headlights and rims
Spartain Tuner w/ Dpf & Doc Delete
2008 Excursion 6.4 Diesel in progress
pdombrowicki is offline
post #6 of 13 Old 03-17-2014, 10:15 PM Thread Starter
pdombrowicki any chance you have one extra old one for the #2 position under the front of the cab? I need the metal parts.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #7 of 13 Old 03-30-2014, 11:45 PM Thread Starter
OK I used some of Daystar's body mounts and solved the squeaking/clunking body mount problem. More info to come.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #8 of 13 Old 10-28-2014, 08:53 PM
Quoted: 6 Post(s)
Which kit did you order? I'm going to have a shop pull the body to do the heads and might as well change these while I'm in there.
Elky57 is offline
post #9 of 13 Old 11-23-2014, 12:49 PM Thread Starter
KF04050BK is the set I used. I am working with them to get a new upper metal sleeve for the drivers foot positions (2). They did fix this perfectly. I made my own upper sleeve with a large washer welded to a piece of tubing base on original mount dimensions.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #10 of 13 Old 12-12-2014, 11:46 PM
Bringing back an old thread.
Tom, did you ever have any luck with Daystar?
My mounts are going and I had already bought that kit above. Figured that they could be modified. I ran into this thread and saw that you had done so already.
How are they holding up with the modification?
Thanks
Housedad is offline
