Rear fan airflow issues - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 02-28-2014, 01:43 PM Thread Starter
Hello,
I have been chasing down gremlins in my rear ac and one of them is that the air coming out of the 4 rear ducts seem very low (in volume) when the fan is on the high position. I can hear the fan spinning loudly in the rear but the air seems just like a slight breeze out of the front 2 vents and the rear are only slightly stronger. I had a 00 Ex back in 07 and don't remember how fast the air came out but in my 06 Explorer and 03 Navigator when the rear fan was on high I could feel a good blast coming out all rear vents. What should I start to look at?
15 F250 XL 6.7L CC LB 4x4 (temp work truck)
03 Excursion Ltd 6.0L ARP studs/HG, turbo back exhaust, K&N CAI, EGR delete, 6.4L banjo bolts, blue spring, coolant filter, IDP tunes, SCT Livewire (regrettably sold)
08 Jayco 31 BHDS G2
96 Regal 258 Commodore
rowekmr is offline
post #2 of 3 Old 02-28-2014, 02:25 PM
Term3's Avatar
Quoted: 2 Post(s)
Check for air flow that comes out behind second row seats, assuming you have the selector going to the upper vents only. If its high then it's an air door issue. I've never opened that system up myself but should be easy to fix.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 3 Old 02-28-2014, 02:29 PM
ZMANN's Avatar
Quoted: 1776 Post(s)
another thing is see if you can detect a change in fan speeds using the selector
We Miss you Ronnie
ZMANN is online now
