Master rear end rebuild kit-best place to get it - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 5 Old 02-24-2014, 06:34 PM Thread Starter
wckdpowerstroke's Avatar
So i need a kit for my 03 ex rear end. It is a 10.25 correct? Where is the best place for price on a master rebuild kit?
Thanks
Mike
Black harley lts w/5k hids , blacked out tail lights w/leds,front & rear maghytec diff covers filled w/amsoil, 3" level kit w/ 3" rear block and 5100 bilsteins. 20" novakanes on 35 toyo mt's. kenwood touch screen w/amped kenwood door speakers w/ jl 10w3 subs, optima batts,ipr egr delete,5" sinister stainless exhaust,livewire ts w/egt probe,roof rack removed,mac air intake, blue spring mod, sinister clnt filter,clnt flush & filled w/elc
To do- make custom air box
wckdpowerstroke is offline
post #2 of 5 Old 03-10-2014, 10:26 PM
What is wrong with the rear end?
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #3 of 5 Old 03-11-2014, 12:00 AM
Quoted: 818 Post(s)
Randy's Ring and Pinion
or
Justdifferentials.com
or
Jeff's Bronco Graveyard
Corey@CNCFAB is offline
post #4 of 5 Old 03-11-2014, 03:31 AM Thread Starter
Bad pinion bearing we think. Got a timken kit of ebay. Now just gotta get it put in
post #5 of 5 Old 03-14-2014, 11:32 PM
If it has symptoms of a pinion bearing going bad I would bet it is the outer/front. Mine was visibly messed up when it came out. If you pull the drive shaft, yoke and seal I have heard you can get the bearing out. The carefully weld the race and pull it out. Much faster and no set up.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
