Considering 05 Ex..... - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 10 Old 01-31-2014, 07:33 AM Thread Starter
Greetings........
I've asked this in another forum, but got no response. Can someone please interpret an Oasis report for me? Anything that would make you walk away from this Excursion? The good? The bad? The ugly?
Swmpbgy1
swmpbgy1 is offline
post #2 of 10 Old 01-31-2014, 07:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
For a 2005 dosnt seem to be much on it. If that worries you my 05 report would scare the shorts off you!
I didn't see anything that woulod worry me.
But if you are looking at buying this truck you gotta get a monitor. If you buy this based on the oasis,that would be like buying a TV based on reading the tv guide.
$150 and you can get a scanguage and find out the true story.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 10 Old 01-31-2014, 08:05 AM Thread Starter
I've been reading quite alot on the 6.0 and understand the need for the monitor on the vehicle during the test drive. One question on the $150 scanguage......If and when I ultimately buy an excursion, if I do the EGR delete on the 6.0, will the scanguage clear the resulting code? Does the code come back and need to be cleared frequently?????
Swmpbgy1
swmpbgy1 is offline
post #4 of 10 Old 01-31-2014, 08:11 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
On a 05 you wont have any issue with a code. But Im also not 100% sure the scanguage will clear the code if you did get it. I know the Edge will but that's a bit more pricey at around $400. But a very usefull tool for sure.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 10 Old 01-31-2014, 08:40 AM Thread Starter
Kinn.......
Let me ask you this.....I've read in several threads about a bluetooth device that pairs with an iPad.....costs are relatively low....will this set up be able to determine the stats I need to make a pre-purchase decision? When I do purchase an excursion, upgrade to a scanguage or whatever????
Swmpbgy1
swmpbgy1 is offline
post #6 of 10 Old 01-31-2014, 09:47 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I think your talking about the livewire. Ive never actually seen one in person but from what Ive seen in magazines it looks pretty good.
If you did get the truck then IMO something like the Edge is almost a gotta get. Mine has saved me more money that it cost me. I now have a turbo timer on it so now I just shut the truck off and walk away and it takes care of its self.
I have my last oil change mileage in it so when I get close it will remind me. It tells me when I'm having to much fun and wasting fuel. It will read trouble codes and erase them....its just a very cool tool to have.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 10 Old 01-31-2014, 10:23 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
Originally Posted by swmpbgy1 View Post
Kinn.......
Swmpbgy1
You're talking about the dashboss app for iphone, ipad, etc. And yes, it'll show you more then you need to know. I don't know to much about it. Search around, you'll find all the info you need. I think you can hook up to read fuel pressure and egt on it, and the total $ is around 250 for everything I believe.
I use the Torque app with my android. $14 and you're in business. It's only for Android devices though. No egt or fuel pressure capability but everything else.
G'luck.
2005 Excursion Limited w/254K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is offline
post #8 of 10 Old 01-31-2014, 10:31 AM
I have the Dash Boss, used it to buy my current rig, it works real good and easy to take with you on a purchase, after getting the truck i went to a live wire
johnrowdy is offline
post #9 of 10 Old 02-03-2014, 04:20 PM
My 04 6.0 Excursion threw a CEL after the EGR cooler was deleted. I had to get a tuner to disable the EGR system and keep the CEL off. The performance shop where I bought the tuner said that all 6.0 Excursions will throw a CEL regardless of year when the egr system is deleted. Apparently the Excursion was held to the California emission standards since its an SUV and not a pickup.
Be prepared to invest in a tuner if you plan to do a delete.
eddieex10 is offline
post #10 of 10 Old 02-05-2014, 08:09 AM Thread Starter
Thanks all for the replies....The EX that is in the Oasis report at the beginning of this thread has 92000 miles on it......400 miles away from me.....If this !@#$%^& weather would break, I'd like to go see it.
Shopping for monitors now.........
Swmpbgy1
swmpbgy1 is offline
