Vibration after repair - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 01-14-2014, 01:24 PM Thread Starter
fordguy_1's Avatar
Okay, I just helped replace the drivers side hub assembly on my brother-in-laws 04 Excursion. It is 4x4, has front ABS and auto hubs. We replaced all the seals and put in a new U-joint since we had it all apart. The vibration started after he drove it on the highway for about 30 min. It only made the noise/vibration when turning left and in drive. Now it makes the vibration/noise when turning right or left and in drive, not in reverse. Any ideas???
fordguy_1 is offline
post #2 of 6 Old 02-08-2014, 11:24 AM
john galt's Avatar
Quoted: 1344 Post(s)
I would check for anything that got loose and do a re-torque on everything. if that doesnt get it perhaps the other side is now complaining out of neglect?
so you will get someone with more experience on these than I
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 6 Old 03-30-2014, 04:42 AM
CBarker's Avatar
Bump, My 03 excursion has a slight vibration and roar on left curves, it doesn't do it on right hand curves. I thought it may need new wheel bearing assemblies too? Anybody with more experience have anything to add.
2003 EDDIE BAUER EXCURSION 6.0, 123K, ARP studs by stroked out diesel, stroked out diesel egr delete, 6" BDS LIFT W/ FOX 2.0's, 37" NITTO TRAIL GRAPPLERS ON 17" FUEL REVOLVER MATTE BLACK, LIVEWIRE TS FROM VIVIAN, LOONEY TUNED, S&B CAI, 4" TURBO BACK MBRP CAT DELETE,KENWOOD DD319,4 KICKER KS68' S
to do list:
pray for Auburn's football program (he answered my prayers)WDE!, rear camera, repair the rear dvd player, Raybestos pro brake rotors and pads, new wheel bearing units
CBarker is offline
post #4 of 6 Old 03-30-2014, 07:45 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Classic symptom of a failing unit wheel bearing.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 6 Old 03-30-2014, 08:47 AM
CBarker's Avatar
THANKS, NYC!!! Not to derail the thread, but do you have any recommendations on an upgrade for the 4x4 auto hubs too. Seems like I've read somewhere that warn assemblies are a little less expensive than the OEM???
CBarker is offline
post #6 of 6 Old 03-30-2014, 09:31 AM
NYC F-350's Avatar
Quoted: 51 Post(s)
The warn hubs will fit the model years that have leaf springs on the front axle.
Please
