Rear Tail Lights for a 2005 - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 5 Old 01-07-2014, 04:24 PM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
I need a new taillight. Bought a new set and they dont seem to fit. do different years of the EX take different rear lights? The package says they only fit up to 2003, but when i bought them online the said fits all years of excursion including 04 and 05. ANyone know?
jeffro22 is offline
post #2 of 5 Old 01-08-2014, 07:06 AM
Tempsho's Avatar
Quoted: 3 Post(s)
Excursion tail lights only fit the Excursion and Econoline vans. It should be the same part from 2000 to 2005. Here are LED taillights I added on my 2002
http://www.amazon.com/IPCW-LEDT-502CR-Ruby-Tail-Lamp/dp/B004I5O70C/ref=sr_1_16?ie=UTF8&qid=1389197110&sr=8-16&keywords=excursion+led+tail+lights
2002 7.3L Excursion Limited 4x4
- 21"/11"/21" Vision X Xmitter Prime light bars (47,000 lumens)
- Edge CS Monitor
- Tymar intake
- Fumoto Quick Drain Valve
- Coolant filter, ELC, 203* T-stat and billet housing
- Riff Raff boots
- PHP Chip (Stock, 80DD, 100Race, Whisper Mode, 80Tow, Smoke Show)
- F350 leafs front and back
- Hellwig rear sway bar, Bilstein 5100's
- LT275/65R20 Durtrac's on 20" King Ranch wheels
- Fred Goeske 2" steel wheel adapters
- Genuine Larry B's Denso starter
Tempsho is offline
post #3 of 5 Old 01-08-2014, 07:45 AM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
from what I understand is that the 04-05 excursion use a slightly different shaped tail light
jeffro22 is offline
post #4 of 5 Old 01-08-2014, 07:53 AM
Tempsho's Avatar
Quoted: 3 Post(s)
I doubt it. Physically speaking, all 00-05 Excursions are pretty much identical. Check what years those tail lights fit
- Edge CS Monitor
- Tymar intake
- Riff Raff boots
Tempsho is offline
post #5 of 5 Old 01-11-2014, 05:25 AM Thread Starter
jeffro22's Avatar
Quoted: 5 Post(s)
Ok, thanks, Got it figured out. The box said the lights fit 00-03 excursion so I was thinking I had the wrong lights, even though I woudl think all the excursions would be the exact same.
For some reason the seal around the actual lens was not the same and had more of a lip on it. It was keeping the light from going in all teh way. I took the seal off my old light and swapped it, and the light fit perfect. So got my cracked taillight swapped out now
jeffro22 is offline
