Minimum lift for 35" tires - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 15 Old 12-09-2013, 10:58 PM Thread Starter
OK time for the suspension to get upgraded on the X. Looks like 35" tires with the smallest possible lift. It will be used off road a little so it must actually clear these tires.
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #2 of 15 Old 12-11-2013, 04:53 PM
I had a 4" and they rubbed at full turn. A minimum of 5" is needed
Sent from AutoGuide.com App
corycicuto is offline
post #3 of 15 Old 12-11-2013, 04:54 PM
Remember the x sits 2 inches lower than a f-250 or 350. So if u buy a 2" lift for a f250 it will raise your x 4"
I also had 20" rims with 35" tires
The Following User Says Thank You to corycicuto For This Useful Post:
Tom Doniphon (12-19-2013)
post #4 of 15 Old 12-12-2013, 05:04 AM
wngnt954's Avatar
I have the 4.5" icon hanger and shackle lift with the V&B spring swap. 35x13.5 clear with no rub.
The Family Truckster
wngnt954 is offline
post #5 of 15 Old 12-13-2013, 12:01 AM Thread Starter
Have any of you done any off-roading with the lifts mentioned? How did the v\b lift do around corners and higher speed curves like the interstate?
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #6 of 15 Old 12-13-2013, 12:04 AM Thread Starter
wngnt954 if the family truckster in the post is your rig with the mods we need a bigger picture!
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #7 of 15 Old 12-13-2013, 08:42 AM
wngnt954's Avatar
That pic was without the V&B code swap. I also changed all the spring and hanger bushings to energy suspension bushings. That with the spring swap really helped that bowl of jello feeling these trucks have. I'll get a updated pic up soon. Needs a bath first!
wngnt954 is offline
post #8 of 15 Old 12-17-2013, 12:37 PM
wngnt954's Avatar
Minimum lift for 35" tires-imageuploadedbyautoguide1387312591.235854.jpgMinimum lift for 35" tires-imageuploadedbyautoguide1387312612.700519.jpg
wngnt954 is offline
The Following User Says Thank You to wngnt954 For This Useful Post:
post #9 of 15 Old 12-18-2013, 06:39 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We have been solving the Excursion handling issues since '04. PM me if I can help.
Getting the correct springs, shocks and hanger kit will transform the handling.
CT Performance, Inc. is offline
The Following User Says Thank You to CT Performance, Inc. For This Useful Post:
post #10 of 15 Old 12-19-2013, 06:25 PM Thread Starter
After looking at things I am thinking of doing V/B's withe the 3". I already have the 2013 20" rim with 34" tall tires on one X with unmodified V/B's only and they are fine.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
