Auto Unlock - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 12-01-2013, 04:27 PM Thread Starter
Auto Unlock
Hello everyone. I recently picked up a 2005 Excursion 6.0 PSD. I love it! One issue I am having is with the door locks. Is there a way to make it so that once the drivers door opens all the doors unlock. I am pretty sure my old 7.3 used to do this and my wifes Ford edge does it now. It may not be possible in the excursion but if it is I would like to do it.
Thankyou.
dtballer05 is offline
post #2 of 6 Old 12-01-2013, 11:58 PM
Ford didn't incorporate this into the trucks until 2008 models.
the only way you can do this is if you install an aftermarket alarm. some of those do the unlock feature. but there is no factory feature for a 99-07 truck or 00-05 Excursion
2002 Excursion XLT: 6.8L
315/75/16 Terra Grapplers
Tons of small upgrades not worth listing
Tylus is offline
post #3 of 6 Old 12-05-2013, 04:25 PM
ATV PRO 11's Avatar
Welcome to the site!!
Yes. With door open, push unlock button.
Razzing ya, I would suggest just using a Ford/aftermarket key fob. Just hit the button and everything unlocks. Other than that I believe it has an auto lock feature only. (putting in drive and auto locks doors) Mine had that when I had it and a buddy reprogramed it using the keypad on the door.
I have a Compustar starter/alarm combo. One push of a button and everythings unlocked.
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #4 of 6 Old 01-01-2014, 07:09 AM
my 2003 will unlock all doors. After you enter the 5 digit pin on driver door press two far right or button at same time and all unlock. Also to lock truck at anytime press two to the left at same time to lock
mtsmith2003excursion is offline
post #5 of 6 Old 01-01-2014, 07:14 AM
c dog's Avatar
I have a 2005 Excursion. If I enter my code it only unlocks the drivers door. If I enter my code and hit #3 after, it unlocks all the doors. If I press the two buttons to the far right at the same time all the doors lock
Sent from my Nexus 7
c dog is offline
post #6 of 6 Old 01-02-2014, 06:41 PM
ok cdog I had it backwards… started to check for sure but thought I was right
