6.0. 03-05 differences - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 22 Old 11-07-2013, 07:43 PM Thread Starter
I know the 05 has different headlights and front grill but are there any differences? In the market to buy.
draaronr is offline
post #2 of 22 Old 11-07-2013, 09:07 PM
Yes the 6.0 after 10-03 (2004 model year) is the later style 6.0. If you look in the door there will be an information tag with the build date. The later builds had updates for reliability.
6.0L Power Stroke Model Year Changes
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #3 of 22 Old 11-07-2013, 09:43 PM
ATV PRO 11's Avatar
Thanks Tom!!
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #4 of 22 Old 11-08-2013, 03:43 AM Thread Starter
gotcha,but no other upgrades to interior or, options?
draaronr is offline
post #5 of 22 Old 11-09-2013, 06:07 AM
Quoted: 3 Post(s)
The interior on the 05 is unchanged. It did not get the facelift like the F-series.
2005 Excursion Limited 6.0L 2wd
Atlas 40, Bulletproof EGR cooler, coolant filter, 6.4L banjos, Cat coolant, Gogo direct solenoid, 7.3 fan clutch. Otherwise, all stock.
bigric is offline
post #6 of 22 Old 11-10-2013, 01:14 AM
05 only models look like 2005-2007 trucks. they get the bumper, grille, headlights, and tow mirrors with blinkers.
00-04 tow mirrors don't have blinkers
otherwise, they're pretty much identical from 2000-2005. colors and slight exterior trims changes are only true differences
2002 Excursion XLT: 6.8L
315/75/16 Terra Grapplers
Tons of small upgrades not worth listing
Tylus is offline
post #7 of 22 Old 11-10-2013, 06:12 AM
Nickellhead's Avatar
I have an 04 excursion and the tow mirrors have blinkers
Sent from AutoGuide.com App
Nickellhead is offline
post #8 of 22 Old 11-10-2013, 06:58 AM
Heathrm's Avatar
What he said, you beat me to it. I thought the grill, bumper and lights were the main changes?
2004 Excursion Limited, 198,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #9 of 22 Old 11-10-2013, 07:07 AM
Term3's Avatar
The '05 has the 100mm water pump not the 90mm one that's in the earlier years.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 22 Old 11-10-2013, 07:39 AM
Heathrm's Avatar
I completely forgot about the water pump. I don't know how as I had to change mine out. Sent them the VIN and they still sent me the wrong one initially!
Heathrm is offline
