04 excursion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 27 Old 11-05-2013, 11:05 AM Thread Starter
Nickellhead's Avatar
04 excursion
Hi, I'm new to powerstroke and diesel world. I recently purchased an 04 excursion limited 4X4 6.0. It has 170,000 miles on it, EGR delete, A.R.P. Studs. 4" diamond eye exhaust straight pipe from turbo back. That's the stuff I've noticed that has been done to it. I've got an issue with coolant coming out of degas bottle only when you get on it I notice it. I've done a coolant flush on it with the ford VC-9 and refilled withe zerex cat coolant. I put an after market coolant gauge on it but haven't seen any temps above 220. I only have heat when I'm on highway. I've replaced the thermostat also. I'd like to get this problem taken care of and then I'd like to try to get around 500-600 horsepower out of it. I know head gaskets have been replaced but don't know what brand nor if heads were machined. That was done before I bought it. Also notice gurgling in coolant system.
My questions are:
What could my coolant issue be?
Is there any updates to this motor I need to look for or do?
And what is best way to achieve my horsepower goals?
Thanks for any info!!!
Sent from AutoGuide.com App
Nickellhead is offline
post #2 of 27 Old 11-05-2013, 01:17 PM
Sounds like you have leaking head gaskets. Are you sure you it has ARP studs? You may need to do a coolant pressure check. Info is on Youtube.
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #3 of 27 Old 11-05-2013, 05:03 PM Thread Starter
Yes. It does have ARP studs. And what I can see of the head gaskets they are black.
post #4 of 27 Old 11-05-2013, 08:08 PM
ATV PRO 11's Avatar
Originally Posted by Nickellhead View Post
My questions are:
1) Head gaskets
2 & 3) I'm new(er) as well. Best idea I can give you is READ READ READ. I have a piece of paper beside me and have spent hours flipping through the forums just marking down little notes here and there on what to look for, who's done what, what's working out there, reputation of who replies when looking for solid answers. My list will hopefully be coming to fruition in the next month or so. Patiently waiting to ask the major questions, IMO, tend to get the main guru's helping you along. If you read and understand alot of the details along the way it doesn't waste alot of their time trying to interpret the thread you've started. These guys/gals here know there stuff
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #5 of 27 Old 11-05-2013, 09:03 PM Thread Starter
Thanks! I have a puzzling thought. I know if the head gaskets were leaking exhaust into the cooling system it would cause it to over pressurize but what really confuses me is if I leave it sit for 3-4 days and then check the coolant it still has pressure on it. If they were leaking and after engine has cooled wouldn't the coolant leak into the cylinder to relieve pressure?
post #6 of 27 Old 11-05-2013, 09:13 PM
Good question! My X with stock bolts did the same. leaked under load out the degas bottle and would hold pressure when cold. They leak under pressure(stretch) not when under low load or off. I have heard of people installing only the studs that are visible to fake out customers before. Do you know who did the studs?
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #7 of 27 Old 11-05-2013, 09:20 PM Thread Starter
The studs, head gaskets (look new from where they hang out of head area), and EGR delete was done before I bought it.
post #8 of 27 Old 11-05-2013, 10:36 PM
Well I have tried some other ways to check that did not work but I would try the pressure test of the cooling system while driving shown in several Youtube videos. If you are getting puking out of the degas bottle on flat ground without a programmer you have a good sized leak somewhere.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #9 of 27 Old 11-05-2013, 10:37 PM
Also as I recall there were some Victor head gaskets called Black something that were known to be bad.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #10 of 27 Old 11-06-2013, 06:13 AM Thread Starter
Thanks! I'll do the pressure test and get back to you.
