- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
03 X, want to upgrade to 05 Headlights and grille
Does anyone know if the 05 and up Excursion/SuperDuty Headlights will swap out with the pre 05 lights? I know the 05+ grille won't swap out without modification but I am eyeing a modified factory 05+ grille on ebay that looks like a well done custom piece.
Just need to know about the headlights, as far as if there are any mounting bracket issues or such, I know there is a need for an upgraded wiring harness, but other than that I'm still researching the possibilities. Thanks for any help provided. |
| Sponsored Links |
Back to the headlights. I'm reading now that with the swap to the 05'+ headlights I will lose my daytime running lights as well as control of the factory foglights with the factory headlight/foglight switch? The simple harness upgrade from dfuser runs around $50, and apparently the harness upgrade that allows use of daytime running lamps and fogs runs around $150, but it still doesn't allow use of the factory headlight switch to operate the fogs? Am I fairly accurate on this? Seems to be a bit more involved than just swapping lights and a cheap harness to retain total factory control. |
I have an 03 limited with the 05 front end. Bought it this way and my fog lights work with the factory switch. The auto funtion works also. I didn't do the conversion, but can't imagine them not working.
| Sponsored Links |
