Finally got one. - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 18 Old 10-25-2013, 08:43 PM Thread Starter
Finally got one.
After several years of searching for the right one, my wife and I found a 2004 Ex Eddie bauer 4x4 with a 6.0 and only 76K on the clock. Took it to a friend at the dealer. The motor is virgin with all dealer recorded oil changes and service. 3* delta, 48.5v on the FICM, plenty of high pressure oil pressure and only a small bed plate seep. EGR cooler is factory and no signs of failure anywhere.
Went to Cummins and bought some restore, restore + and ELC. Time to start the flush. So far I love this thing. Tow as much as my 250 and haul 8 people.
2005 F250 Everything that can be done, has been.
Swamps FICM, ARP Studs, BPD EGR cooler and remote oil cooler, 6.4 banjo bolts, blue spring, HPOP, 4 turbo back and all the other crap that Ford should have done right.
2004 Excursion Eddie Bauer untouched...for now
DarinCraft is offline
post #2 of 18 Old 10-25-2013, 09:01 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
DO NOT FLUSH WITH CHEMICALS. You have a 3 delta why on earth would you screw with it now? Just dump the coolant and stick the garden hose in the degas bottle and turn it on and let it run with the radiator petc0ck open and both block drain plugs out and let it run like that for 15-20 mins (of course make sure the water is on for the hose first). Then get about 20-25 gallons of distilled water and flush it all through until it's all gone. Drain the block and radiator and then fill up with CONCENTRATE EC-1 rated ELC coolant and call it good.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 18 Old 10-25-2013, 09:12 PM Thread Starter
I don't even know how to respond to that.
post #4 of 18 Old 10-25-2013, 09:14 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Lol is that a good or bad thing?
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 18 Old 10-25-2013, 09:36 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
hes right you would be a fool to flush it. do it exactly the way he said. I get a coolant filter watch and monitor it and change it when needed.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #6 of 18 Old 10-25-2013, 09:39 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
A thank you and 20% is customary.… lol I kid, I kid.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 18 Old 10-25-2013, 09:41 PM
Quoted: 7 Post(s)
but in all seriousness pay up.
post #8 of 18 Old 10-25-2013, 09:43 PM
KillNThrill24's Avatar
I think he's saying you stuffed a lot of things in a small amount of words hahaha. It took me 2 read through's to get it myself. But yeah man your dead on with your info!
2000 F350 Lariat CC LB, 00 Mustang GT, 01 turbo Cobra
KillNThrill24 is offline
post #9 of 18 Old 10-25-2013, 09:44 PM Thread Starter
Well thanks for stopping by to call me names, but I think I'll stick with Mitch's advice (PgreenSvt) on this one.
post #10 of 18 Old 10-25-2013, 09:49 PM
I called no names...
