Excursion Hitch Replacement - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 10-23-2013, 07:22 AM Thread Starter
Question Excursion Hitch Replacement
So my hitch pin hole is worn out and elongated from the previous owner and my trailer is just adding to it.
I was looking for a replacement hitch for the ex but cant find any. So does anyone know if the f-250 hitch will bolt up?
If I cant find someone to do a quality repair to the hitch I would rather not pay dealer prices.
Thanks!
Ndekens is offline
post #2 of 3 Old 10-23-2013, 07:27 AM
I would imagine that you could possibly have some thick, hardened washers welded to the outside of the holes for the pin. I would imagine that the pin would still be long enough to clip on the other side. This would most likely be the cheapest (and still safe) fix.
Sent from AutoGuide.com App
Jeremy
2005 EB Excursion 6.0 4x4
'97 F250 7.3L PSD CC/SB Auto (Gone)
KS97PSD is offline
post #3 of 3 Old 10-30-2013, 03:22 AM
Therabbittree's Avatar
The whole excursion hitch is
tough to find, i think only 1 or 2 manufacters make one.. especially a class 4 hitch. The reason is the hitch is used as crash support for the rear frame / fuel tank. it has special bolts in it also.. I 'm looking into getting a class 4 or doing a custom beefier hitch made up myself.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
