OEM brake controller in Ex - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 10-20-2013, 01:01 PM Thread Starter
FiremanDan's Avatar
I have an 04 Ex and am wanting the factory brake controller. I see them in 05 Trucks but never in the Ex. Will a factory BC fit in the hole in the Ex dash? Or will I need to put an F250 dash in? Thanks!
Sent from AutoGuide.com App
04 Ex Limited 4X4 6.0 early, XDP coolant filter, BPD EGR, Rotella T6
FiremanDan is offline
post #2 of 6 Old 10-21-2013, 11:33 AM Thread Starter
FiremanDan's Avatar
No one has any info on this?
post #3 of 6 Old 10-21-2013, 11:48 AM
PowerStrokedRedneck's Avatar
From what I understand, the Exs never got the newer systems as the 05+ pickups did. So the OEM controller you want wouldn't work unless you did a lot of work.
PowerStrokedRedneck is offline
post #4 of 6 Old 10-21-2013, 01:25 PM Thread Starter
FiremanDan's Avatar
Ok, makes sense, they knew it was nearing the end. I thought i read somewhere that someone put an 05 dash in with the controller. Thanks for the reply!
post #5 of 6 Old 10-22-2013, 06:28 AM
Therabbittree's Avatar
I think you could do it, but lots of $ the factory controller works off the master cyl..lots of $ to get the parts, master cylinder, wiring, lower dash etc etc, and a regular electric one would work well and be alot easier and cheaper.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #6 of 6 Old 10-22-2013, 07:03 AM Thread Starter
FiremanDan's Avatar
I was just thinking if I could do it for a couple hundred, then I might do it. Thanks all for the great info!!
