V / B code springs - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 09-17-2013, 02:32 PM Thread Starter
V / B code springs
I am in the process of removing a lift kit from my 2005 X and doing the V/B code upgrade with Cary. Because I bought the truck with the lift already on I have been going around gathering all of the stock components, including the stock rear springs for the B mod. While I was picking up the stock springs the guy said they just had a 2004 F250 come in and I have first dibs on any suspension components. How do I tell if this truck has the V/B springs on it?
JJensen79 is offline
post #2 of 6 Old 09-17-2013, 03:39 PM
c dog's Avatar
I would like to know also how to tell what springs the truck has or if they are marked on the springs themselves.
BTW why did you take the lift kit off?
c dog is offline
post #3 of 6 Old 09-17-2013, 04:50 PM Thread Starter
I am working on getting it off. I am waiting for the new tires to arrive and I still have to place my order with Cary then I can do the swap.
post #4 of 6 Old 09-17-2013, 04:51 PM Thread Starter
I am taking it off because this will be my wife's primary vehicle and she doesn't like it.
post #5 of 6 Old 09-17-2013, 04:58 PM
c dog's Avatar
How much lift? Message me if you want to sell it.
Sent from AutoGuide.com App
c dog is offline
post #6 of 6 Old 09-18-2013, 03:50 AM
Therabbittree's Avatar
There is a sticker on the door jam it will have the spring codes listed under the spring section - front spring code then rear spring code. Also do a search for the spring codes part #'s. The stamped part number will correlate to a alphabet code. Also the ford Work Shop / Service Manual has them listed in the front section.
Here's a list I did over on Diesel Stop in 2009
X Codes..F81A-5310-AFA, stamped #3034AFA, Suffix AHD, Weight 2,600lb.
W Codes.. ? - ? - ? -?-?-, stamped # ?-?-?-?- , Suffix AGD, Weight 2,400lb.
V Codes..2C3Z-5310-HA , stamped #3C34ADA , Suffix AFD, Weight 2,200lb.
U Codes..2C3Z-5310-GA , stamped #2C34ACB , Suffix AED, Weight 2,000lb.
T Codes.. ? - ? - ? -?-?- , stamped #F81AADD , Suffix ADD, Weight 1,800lb.
S Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix ACD, Weight 1,600lb.
H Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix HA, Weight 2,250lb.
G Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix GA, Weight ?
D Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix DA, Weight 1,980lb.
C Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix CA, Weight 1,780lb.
B Codes.. ? - ? - ? -?-?-?, stamped # ?-?-?-?-?, Suffix BA, Weight 1,680lb.
Front Spring Part # vs Code - Diesel Forum - TheDieselStop.com
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
