Going Under The Knife - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 14 Old 09-13-2013, 04:23 PM Thread Starter
FordGuy100's Avatar
Clearance on the front, just a wee bit tight, had to take the front bumper off.
Going to go slow for a while, have many things that need addressed. Full time work/school/family means I can only sacrifice 8-10 hours a week without killing grades.
Getting a BPD oil cooler as...
Just a tad to high delta wise (this was towing around 5500 pounds)
Head studs, gaskets, etc.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #2 of 14 Old 09-13-2013, 06:42 PM
Heathrm's Avatar
You have room to spare!!!
2004 Excursion Limited, 198,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #3 of 14 Old 09-16-2013, 04:38 AM
Therabbittree's Avatar
That's going to be tight. Congrats on taking it on yourself! I am doing mine also. Time is my problem, so much stuff going on!...
Keep us posted.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #4 of 14 Old 09-16-2013, 11:58 AM Thread Starter
FordGuy100's Avatar
Keep us posted.
Thanks,
Deo
Your build is exactly what I want to do, I just don't have the time nor the resources
-Justin-
post #5 of 14 Old 09-17-2013, 04:03 AM
Thanks for the compliments!.. I will be following your build.
Thanks,
Deo
post #6 of 14 Old 09-24-2013, 12:03 PM Thread Starter
FordGuy100's Avatar
Got a late start today, started at 11am
11:30AM
1:15pm
Eating lunch now. Intake is unbolted waiting on turbo removal. Thatwill probably wrap it up for the day.
-Justin-
post #7 of 14 Old 09-24-2013, 01:13 PM Thread Starter
FordGuy100's Avatar
3pm
Working till 4. Oil cooler is coming out next
-Justin-
post #8 of 14 Old 09-24-2013, 01:48 PM Thread Starter
FordGuy100's Avatar
Alrighty, done for the day. This is as of 3:35pm, so about 4 hours of work today if I take out lunch time.
-Justin-
post #9 of 14 Old 09-24-2013, 01:53 PM Thread Starter
FordGuy100's Avatar
Much nicer to have the intake unbolted, unbolt the turbo and push it up off the drain, pull the intake out, then pull the turbo. Pulling the turbo over the intake (that's what I did when I did the EGR delete) is much harder as there is almost no clearance.
I also wish I had pulled the wiring completely from one side so it wasn't laying across the valley like that. Didn't cause any problems besides me not wanting any wiring to fall into the oil.
Next time I'm pulling the AC crapola from the firewall. Got to research that first to see what I'm up against.
-Justin-
post #10 of 14 Old 09-24-2013, 01:57 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
..........im glad i dont have a 6.0
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
