05' with new turbo - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 10 Old 09-08-2013, 10:35 AM Thread Starter
05' with new turbo
I'm looking at an '05 and the owner said he just had the turbo replaced. Is this a red flag? Should I be looking for other issues tied to this?
Thanks
Trainrunner is offline
post #2 of 10 Old 09-10-2013, 05:26 AM
Therabbittree's Avatar
With a 6.0L there could be tons of issues. A replaced turbo isn't neccessarly a red flag. Depends what they used foe turbo and etc. Could have saved you some $.
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #3 of 10 Old 09-10-2013, 05:36 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would not be concerned at all with a changed out turbo. But before you buy any 6.0 you need to invest $150 and get a monitor. Learn how to use and read the monitor which can save you thousands.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 10 Old 09-10-2013, 05:50 AM Thread Starter
Thanks, I'll definitely get one. Any suggestions on what monitor.
post #5 of 10 Old 09-10-2013, 06:08 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Cheapest would be the scanguage. (150) Most guys run the Edge cts (400) But either way they will pay themselfs back multifold!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 10 Old 09-10-2013, 07:22 AM
A turbo swap could be related to NOT letting the EGTs spool down to 400* before shut down. I had a turbo replaced at 40K in my then new to me 2003. I've put 60K on the current turbo shutting down at 400* religiously.
High EGT at shut down will eventually coke the oil in the turbo.
I have a Scan Guage II, but for boost, fuel psi, and EGT, I rely on Auto Meter.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 10 Old 09-11-2013, 09:14 AM Thread Starter
Thanks I'll make a note of that.
post #8 of 10 Old 10-09-2013, 06:56 AM
The cheapest is actually an android device with the "torque app" and a bluetooth OBDII connector (ELF 32 something on eBay).. This totals out to under $20.00.. Works great.
MightyMouse75 is offline
post #9 of 10 Old 10-09-2013, 07:01 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Very cool,never seen that one. As long as it covers the basic's.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 10 Old 10-09-2013, 07:53 AM
It covers just about everything you need to monitor..
Newegg.com - Mini V1.5 ELM327 OBD2 Bluetooth Interface Auto Car Scanner Diagnostic Tool for Android
That's the adapter.. Torque software is out there.. There's a free version and a paid version.. You want to pay the $5.99 or so for it. It lets you check engine codes and reset them as well. Since it's R/W I'm sure it can eventually be used to tune the engine as well...
