Bought a modified 2005 Ex. Now what? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 6 Old 08-23-2013, 07:36 AM Thread Starter
Hi Guys,
I haven't been around in a while because I've been Powerstroke-less since I traded in my 1995 F350. I'm back in the PS saddle again with my second Ex. Last one was a 2000. I bought this 2005 because it is a clean southern truck, it has the options I like and it has already had some preventative/performance mods done. It has head-studs, RCD EGR block, RCD oil-cooler, S&B intake, 4" MBRP exhaust, upgraded turbo (unknown specs) and an Edge Insight CS. That seems to be a pretty stout foundation for building more power. The turbo seems just a little laggy down low and will give me some turbo chuff if I let off too quickly while it's making considerable boost. I wonder what has been done to it? I need to do some further investigation.
I first thought the truck had an Evo programmer on it because of the way it pulls and breaks the tires loose, but it turns out it's just the Insight model. I'm not sure if it has had injectors installed, IDM work, or anything else.
Any thoughts on what to do next to the truck? I was thinking about some real gauges and maybe a SCT Livewire?
2005 Excursion 4x4 LTD with ARP Studs, EGR Block, Upgraded Oil Cooler, S&B Intake, Unknown Turbo Mods, 4" MBRP and Edge Insight CS
steelsoldiers is offline
post #2 of 6 Old 08-26-2013, 09:50 AM Thread Starter
Update: looks like the truck has also had some suspension work done to it. The front leaf packs look pretty new as they still have the Ford shipping label on them. The rears look like they have had some leaves added/swapped. It seems to ride better than my 2000 for sure.
post #3 of 6 Old 08-26-2013, 04:19 PM
jaysshortbus's Avatar
its a good looking Ex !!
Jay
jaysshortbus is offline
post #4 of 6 Old 08-27-2013, 06:14 PM Thread Starter
Thanks Jason!
post #5 of 6 Old 09-05-2013, 04:52 AM
Therabbittree's Avatar
probably has the v&b code suspension swap. Looks nice!
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #6 of 6 Old 09-06-2013, 10:51 AM Thread Starter
Kinda what I was thinking. Rides great, so I am happy. Thanks for the compliment.
