hub bearing. - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 5 Old 08-17-2013, 12:18 AM Thread Starter
lostparrot's Avatar
hub bearing.
Hi,
I have a 2005 Ex.4x4. I'm pretty sure my front hub bearings are shot. I've looked, and it seems like I have to replace the entire hub assembly. Is this correct? Autozone sells front hub bearings,part number D15101. Are these not what I'm looking for? Or am I buying hubs? Thanks!
Not all who wander are lost
2005 Excursion 6.0 diesel. eddie bauer.
lostparrot is offline
post #2 of 5 Old 08-17-2013, 07:10 AM
Yes, it is a bearing assembly. You really need to scourn the interweb for the best price on Timkin bearings, I tried TWO from Circle K auto parts and they both had excessive bearing ID. In fact, I trashed one in less than 6 months. I ended up getting one at NAPA because I needed my truck NOW. If I would have been able to wait, I found similar priced, but Timkin.
Rock Auto has several to chose from, remember two very improtant things:
1. You get what you paid for.
2. 14x1.5 is fine thread, 14x2.0 is coarse thread. Unlike SAE that counts threads per inch, metric measures space between threads. Anyway, fine or coarse WILL matter.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 5 Old 08-17-2013, 07:28 AM
Quoted: 761 Post(s)
You need the whole hub assembly. The bearings are pressed/torqued in. Don't buy the cheap autozone or off brand bearings. Stay with Timken or SKF. Typically, not always, off brand stuff you will be replacing again within a couple years depending on amount of miles you drive. RockAuto or PartsGeek will have much better prices than local parts stores. Possibly half the price for same Timken units.
Corey@CNCFAB is offline
post #4 of 5 Old 08-17-2013, 08:17 AM
asian195's Avatar
Quoted: 2 Post(s)
Please, do not buy cheap wheel hubs. I did cause money was tight, a year later after being towed home, I was replacing both of them again.
Cheap wheel hubs+ tow bill+ quality hubs= more than doing it right the first time...
Search around online, you can find good prices for good timkens.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #5 of 5 Old 08-17-2013, 10:45 AM
Brew_WY's Avatar
Garage
Here are some part numbers for you. Not all of them are required, but you may be interested in changing some other things while you have it torn down. I found Amazon had the best prices when I did this last summer.
Timken Unit Bearings (14.x1.5mm) : SP580205 SP580205 Seal: BRS84 (Not sure which one this is, haven 't researched it yet)
Front Axle Oil Seal: 3C3Z3254CA
Seal Asy-Trans Diff: 2C3Z3254AA
Front Axle U-Joint: PUJ1 (This was the number he listed, he said he sourced from Napa, didn't come up with anything on a search.)
Front Differential Oil: Amsoil Severe Gear 75w90
2003 6.0L PSD Excursion Limited 4x4
Edge Insight CTS w/Dash Pod, EGT, TT, Back Up Camera
AMSOIL with REV-X
AMSOIL Bypass Oil Kit
GDS Fuel Spring
Diesel Site Coolant and Transmission Filters
Brew_WY is offline
