Replacement jack - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 07-31-2013, 07:54 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
Replacement jack
I picked up a used 03 Excursion. It has the bottle jack, but is missing the jack handle and lug wrench. They're not on the radiator and I don't have a spare tire cover, so no pouch. I talked to the local Ford parts counter and the handle assembly is discontinued.
I'm thinking a bottle jack on potentially uneven road shoulders isn't really a great idea anyway. So, I'll probably look for some generic scissor jack etc. and a 4 way lug wrench for more leverage.
I'm thinking I need at least 3 to 4 ton lift capacity and I'll need to measure off to make sure the max height is enough. Any opinions? Anyone else replace their jack and happy with their choice?
Thanks,
Moose
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #2 of 3 Old 07-31-2013, 11:47 AM
Therabbittree's Avatar
A big bottle jack, and a pate and or wooden block for cribbing is safer then the stock jack, you can get a regular floor jack and remove the handle for storage.
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #3 of 3 Old 08-06-2013, 09:48 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
I ended up buying this for $40 at Tractor Supply:
Powerbuilt® 3 Ton Jack & Jack Stand - Tractor Supply Online Store
It seems beefy enough, has a nice wide base, and should cup under the axle nicely.
ynpmoose is offline
