Need rear leafs like now opinions needed - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 9 Old 07-25-2013, 06:51 AM Thread Starter
Well in my crappy lift kit I bought from superlift 8" lift for early 99 they gave me a block and add a leaf well both add a leafs snapped in two different places and don't trust this block idea but anyways I need rear leafs because it's the season were I tow alot big loads and the weight is makin my truck sag to much hard on my shocks, anyways I seen this ad on craigslist at the bottom and wondering if any of you heard of this company? Also I need suggestions on good leaf springs I want a good set of leaf springs that'll last and won't sag in a year I'm in md and don't wanna spend a grand
E99 F-250, 8" Super lift 39 xmls, TW tuner, Led clearance, running lights, 6637, 10" stacks, xd hoss 795 wheels, etc...
Bradley3054 is offline
post #2 of 9 Old 07-25-2013, 03:25 PM
alaskan155's Avatar
Quoted: 66 Post(s)
not sure on the company you listed(not showing), but the problem may not be the add a leaf/blocks.
but you may be snapping the leafs because of axle wrap(common on lifted super-duties),
i would invest in airbags/ traction bars
i hear with a lift(especially 8") and towing is asking for a ton of axle wrap,
here is what axle wrap is
and how traction bars help it
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 9 Old 07-25-2013, 03:31 PM
Raul@Stealth Automotive's Avatar
with that large of a lift and the amount of torque our trucks pull i suggest getting some traction bars... also remember the larger the curve on the spring means that it wont hold as much weight so if your going to tow i suggest PMF's traction block setup....
-Raul
Raul@Stealth Automotive is offline
post #4 of 9 Old 07-26-2013, 03:20 AM Thread Starter
If I do the pmf traction bar setup that doesn't help me with my springs, I took the add a leafs out so I'm un level, I found oem 350 springs for 175$, are you saying erasing the blocks and goin all spring is bad?
Heres that link must of forgot to post it LIFT LEAF SPRINGS 8 TO 18" WHOLESALE PRICES LIFETIME WARRANTY FORD
post #5 of 9 Old 07-26-2013, 08:12 AM Thread Starter
need someone to tell me the perfect setup so i can make some purchases
post #6 of 9 Old 07-26-2013, 03:38 PM
Therabbittree's Avatar
You should do some research on this or other forums, powerstroke nation , powerstroke army, diesel stop etc... and definately buy or build some traction bars. I had 8"BDS lift on my excursion and if it didn't have the traction bars it would have been rough..definately no pulls. By the way you are posting in the Excursion section , you may hvae better luck in the general 6.0L , 6,0L suspension drive line section, or the performance 6.0L section...
Good Luck,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #7 of 9 Old 07-26-2013, 04:33 PM Thread Starter
Good Luck,
Deo
Crap your right it sucks doin this on your phone sometimes, I actually have 7.3 but u said u had bds I just got priced a guy can get me bds 8" spring and u bolts for 680 area and said there made in Canada this true? That'll mean there good springs and all I would need to do is traction bars
post #8 of 9 Old 07-26-2013, 05:10 PM
Deaver Suspension
they can make springs with about any amount of lift for about any amount of weight and still ride good
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #9 of 9 Old 07-30-2013, 01:18 PM Thread Starter
Is anyone able to answer my question about bds springs?
