Fummins Excursion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 9 Old 07-11-2013, 07:49 PM Thread Starter
Fummins Excursion
Has anyone on here put a cummins in a 2005 excursion and what was the cost, time line. anything will help.
4mywife is offline
post #2 of 9 Old 07-11-2013, 08:10 PM
Brew_WY's Avatar
Garage
Its called google. These guys would be your best resource as they have done many of them. Home | Diesel Conversion Specialists another website that has a lot of good conversion information is www.4btswaps.com .
2003 6.0L PSD Excursion Limited 4x4
Edge Insight CTS w/Dash Pod, EGT, TT, Back Up Camera
AMSOIL with REV-X
AMSOIL Bypass Oil Kit
GDS Fuel Spring
Diesel Site Coolant and Transmission Filters
Brew_WY is offline
post #3 of 9 Old 07-11-2013, 08:26 PM
DieselnDrums's Avatar
if you want you can go check out destroked and they have a "truck builder" page and you can select the options you would be using, like engine, trans, year of truck etc. or diesel conversion specialists. alot depends on how much you are gonna do your self and what engine/trans you're gonna use. do you have a donor truck?
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #4 of 9 Old 07-11-2013, 08:38 PM
I know this is off topic..but has anyone seen a 6.4 or 6.7 conversion done to an ex? I did t see anything in the threads mentioning it.
hpgkmc is offline
post #5 of 9 Old 07-12-2013, 07:35 AM
I don't think it would be worth it. But with enough time and money and resources anything is possible. I personaly have never heard of someone doing an engine conversion with those engines but there are a couple of guys out there that do complete ex conversions on the 6.4 and 6.7 trucks. I know that you would not be able to use the original dash in the excursions. I'm pretty sure you would have to swap out the entire dash.
post #6 of 9 Old 07-12-2013, 04:15 PM
Brew_WY's Avatar
Garage
I know a while back there was a guy here on the forums doing a 6.4L Full Harely Davidson conversion to an Excursion. I don't know if the project ever got finished or not.
I also found this....
2008 Harley Davidson Excursion For Sell
Cheers,
Brew
AMSOIL with REV-X
GDS Fuel Spring
Brew_WY is offline
post #7 of 9 Old 07-12-2013, 04:27 PM
BIG Laing's Avatar
Nope, other way around is so much better! Put an EX shell on a 08+ truck.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #8 of 9 Old 07-13-2013, 10:40 AM
Term3's Avatar
2008 EXCURSION UPDATE
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #9 of 9 Old 07-14-2013, 07:10 AM
Term3's Avatar
You would need to get a fuel tank that goes behind the axle and that means some frame crossmember cutting.
Term3 is offline
