rear window won't lock - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 3 Old 07-03-2013, 01:23 AM Thread Starter
Greetings folks! My rear window will NOT lock. Not with remote, door locks, or even the key. I've taken the panels off to expose the locking mechanism just to see what kind of movement there was while attempting to lock the doors. There is a little movement but not much. I actually may have 2 issues.. the driver's side latch is disconnected because it was causing the "open door" light to come on & having an effect on how the truck locked. It caused a double-honk of the horn with on only 1 push of the button and caused the dome lights to stay on for a longer time than normal. I have not actually removed the locking mechanism yet, but wanted to check for some feedback first. Is this usually a quick fix, meaning throw in a new mech and call it good? it looked like there were only 4 bolts holding the mech in place... is it that easy to remove?
Another totally separate question.... Any folks on Oahu? Just moved out here for work and there aren't too many rigs rollin around...
THANKS!!!
Brickhouse Brown is offline
post #2 of 3 Old 07-04-2013, 04:54 PM
abovetec's Avatar
Mine is doing the same thing, but I haven't opened it up. And it's not the rear window, it is the rear lift gate lock. I am hoping it was like a fix I did on a GMC once, which was a $10 piece of plastic part that I found on eBay.
2004 Excursion Limited 4x4, 6.0 L with Superchips programmer
abovetec is offline
post #3 of 3 Old 07-10-2013, 11:15 AM
This is discussed at length in the Excursion forum at ford-trucks.com.
My rear lift gate lock has stopped working twice now in my 14 months of ownership. It didn't work when I bought it and I just had to fix it again a couple days ago. All it needs is a good clean and lube.
Access the locking mechanism by removing the inside lower panel on the lift gate. Here's what I did - using compressed air, I blew all the dust out of the lower lift gate area. I then sprayed the mechanism down very good with carb cleaner. Sprayed some more while working the key back and forth. I then sprayed silicone on the mechanism again while working the key. At this point the mechanism started moving it's full motion and lock and unlock was working again. With a flash light, if you look closely, you can see how easy it is for this mechanism to bind up if not perfectly clean and lubricated. I used a q-tip and some synthetic wheel bearing grease and worked some grease in the best I could (not sure if this will help or hurt; time will tell). Obviously it's a lousy design. The lift gate lock on my '91 LandCruiser has always worked perfectly without me every touching it. Part of the problem appears how easy it is for dust to get into this area. Mine was very dusty after spending a lot of time on dirt road this spring. In an attempt to limit the dust intrusion, I sealed up the 3 holes towards the center on the bottom of the lift gate. That still left holes on each end for drainage. I don't think it will make a big difference, but anything to help can't hurt.
2005 Excursion Engine: EGR/CAT Delete, Innovative ECM Tune, PHP FICM Tune, coolant filter, stock TTY head bolts and Ford Gold Coolant. Suspension: Bilstein shocks; V Codes springs on front; RAS and Air Lift airbags over stock rear springs.
mmuthart is offline
